Sound Waves: Help Solving Problems
  • Thread starter Thread starter motherlovebone
    Sound
The discussion focuses on solving two sound wave problems involving speed, frequency, and wavelength. In Problem 1, the distance to a reflecting object is calculated using the formula d = vt, where the total time is 2.60 seconds, leading to a distance of 429.8 meters (not 891.8 m). In Problem 2, the wavelength range for violin notes is determined using the formula λ = v/f, resulting in wavelengths from 0.129 meters to 1.735 meters based on frequencies of 196 Hz and 2637 Hz, respectively.
  • Understanding of sound wave properties and behavior
  • Familiarity with the formulas d = vt and λ = v/f
  • Basic knowledge of frequency and wavelength concepts
  • Ability to perform calculations involving speed, time, and distance
  • Research the relationship between frequency and wavelength in sound waves
  • Explore the effects of temperature on the speed of sound
  • Learn about sound wave reflection and echo principles
  • Investigate advanced sound wave phenomena such as Doppler effect
Students studying physics, educators teaching sound wave concepts, and anyone interested in understanding the principles of acoustics and wave behavior.
motherlovebone
I have been stumped on these problems for about a half an hour now, and I need some big help on them!
Problem 1:
"A sound wave traveling at 343 m/s is emitted by the foghorn of a tugboat. An echo is heard 2.60 s later. How far away is the reflecting object?"
I guessed that 2.60 s was the period, so I found the reciprocal to get the frequency. Once I did that, I put the speed of sound in for v in the equation v=frequency x wavelength. My answer, 891.8 m, sounds preposterous however.
Problem 2:
"The notes produced by a violin range in frequency from approximately 196 Hz to 2637 Hz. Find the possible range of wavelengths produced by the instrument when the speed of sound is 340 m/s."
For this one, would I use v=frequency x wavelength? I did 340 divided by 196, which was 1.735, then 340 divided by 2637, which was 0.129. So would the range of wavelengths be 0.129 to 1.735?
Problem 1:
You know the distance, "d" traveled by the wave is equal to the velocity times the time: [tex]d=vt[/tex]. So if the sound is heard 2.6s later then the distance it must have traveled would be the distance from the boat to the wall plus the distance from the wall to the boat. In other words, twilce the distance fom the wall.
Problem 2:
I don't know where to start, these were not explained in class today. Please help!
The wavelength, [itex]\lambda[/itex] is equal to to the speed of the wave, v, over the frequency, f:
[tex]\lambda=\frac{v}{f}[/tex]
So the maximum and minimum frequency give you the minimum and maxximum wavelength. By the way, in case your interested in where this formula came from, it makes sense. A frequency of, say, 2 Hz means that 2 waves pass you in 1s. If the waves are traveling at 10 meters every second and two pass you in a second, then they each must be 5 meters long, so [itex]\lambda=\frac{v}{f}[/itex]
  • · Replies 19 ·
  • · Replies 33 ·
