Calculating Charge Distribution on Isolated Conducting Spheres
The discussion revolves around calculating charge distribution on two isolated spherical conductors with different radii, each initially carrying a positive charge. Participants explore how charge redistributes when the spheres are brought together and then separated, as well as the implications of charge density and electric potential in related scenarios.
  • The original poster attempts to reason through the charge distribution based on surface area ratios and questions how charge density changes when the spheres are in contact. Other participants discuss the implications of equalizing charge density and the mathematical relationships involved in calculating the original charge based on force measurements.
Participants are actively engaging with the problem, offering insights into charge partitioning and density. Some have provided calculations based on their reasoning, while others are questioning assumptions about charge distribution and density equality upon contact.
There is mention of missing notes and uncertainty about previously covered material, which may affect the clarity of the discussion. Participants are also navigating the implications of their assumptions regarding charge behavior in different scenarios.
BananaMan
The question i am stuck on and am unable to find anything in my notes about (although i can't find my notes from tuesday however we seem to have covered the topic on friday and maybe just not finished it off in time) is ...
Two isolated spherical conductors one with radius R and one with radius 3R, each carrying a positive charge Qo. The spheres are brought together and then separated again, find the charge on each sphere.
from what i can think they would act as one surface and the charge would evenly distribute over the whole surface, then i would work out the surface area of each sphere separately and take a ration and then spread the charge of 2Qo over each sphere and give my answer in terms of Qo?
then a little more difficult
if a small charged sphere is brought into contact with another identical sphere which has no charge then separated by 10cm the force between them is 9x10^-3N what was the original charge on the first sphere
it relates to my answer from before, if i am right with what i said above, would i work out the difference between the 2 and work out the respective charges, then add them together to get the charge originally on the first?
any and all help greately appreciated, thanks
Think of electric potential and charge density.
The sphere of radius 3R has 9 times the surface area of a sphere of radius R. If they have the same charge, what can one say about charge density?
well the formula is charge density = Q/A so the charge density must be 9 times higher on the small sphere, however when they are touched together would this mean that the charge density would try and become equal on both surfaces?
worked through it on this assumption
σ1=9σ2
after
σ=Q/A
σ=2Qo/10=1/5Qo
sub back new value of sigma
1/5Qo*1= 1/5 Qo on small sphere
and therefore 2-1/5 = 9/5 Qo for the large sphere?
if this works then for the second question σafter = 1/2σbefore on both spheres
then using F=(q1q2)/4*pi*Eo*r^2
9x10^-3 * (4*pi*Eo*0.1^2) = 1/2Q * 1/2 Q where Q is the charge on the first sphere originally
solving for Q
1.00x10^-14 = 1/4 Q^2
Q = 2.00x10^-7
that right? thanks again
Correct. In the first problem, the charge is partitioned according to area.
Sphere 1 would have charge QA1/(A1+A2) and Sphere 2 would have charge QA2/(A1+A2) where Q = 2Qo
In the second problem, the charge is halved on both spheres of the same size.
thanks, glad i managed to work it out, hope something like that comes up in my exams
  • · Replies 21 ·
  • · Replies 18 ·
