Thread Closed
Topology (Boundary points, Interior Points, Closure, etc...)
Share Thread Thread Tools
Mar4-06, 07:20 PM   #1
Hi.
Can somebody please check my work!?
I'm just not sure about 2 things, and if they are wrong, all my work is wrong.
1. Find a counter example for "If S is closed, then cl (int S) = S
I chose S = {2}. Im not sure if S = {2} is an closed set? I think it is becasue S ={2} does not have an interior point, and 2 has to be a boundary point, (and 2 cannot be both and interior and a boundary point.) Im sure S={2} is closed!
cl (int S)
=cl (int 2)
=cl (empty)
= empty
and that is not equal to S = {2}
2. Let A be a nonempty open subset of R and let Q be the set of rationals. Prove that (A n Q)   .... (I hope those symbols show, I got them from MS Word)
I figured that Since "A is a nonempty open subset of R," A has to be composed of MORE than 1 element, hence, A has to have 2,3,4.... elements.
And I know (from lectures and the text book) that between any 2 real numbers, their is a rational. Hence, (A n Q)  .
How does that sound? Can somebody please check this? Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar4-06, 07:41 PM   #2
Recognitions:
Homework Helper Homework Help
Your answer to 1 sounds good, as long as your considering {2} as a subset of R with the usual topology.
For 2, I assume by your answer that you want to show:
[tex] A \cap Q \neq \emptyset[/tex]
To be more rigorous, you should show that A must contain an open interval and that any open interval in R must contain some rational numbers.
Mar4-06, 07:53 PM   #3
Quote by StatusX
Thank you for confirming my answers!
Yes, for 2), I was trying to find [tex] A \cap Q \neq \emptyset[/tex] ... but im sure Im on the right track for that!
Mar5-06, 02:51 AM   #4
Recognitions:
Defintion of open:
A is open if for any point a in A there is an interval (x-e,x+e) contained in A for some e>0 (e depends on a).
Now, you need to show that this has a rational number in it, which can be done in many ways of varying highbrow-ness.
Mar5-06, 09:37 AM   #5
Quote by matt grime
Defintion of open:
Thats right! i never thought of it like that.
A is open if all the points in A are interior points, and a point x in A is an interior point if a Neighbourhood of x is contained in A ... just like you said, (x-e, x+e).
Since A is a subset of the Real Line, it contains Q.
I have another Question. Prove: An accumulation point of a set S is either an interior point of S or a bounadry point of S
Would it be okay if I write: "If a point in S is either an interior point of S or a boundary point of S, then it is an acculumation point."
I personally find my above "If - Then" statement MUCH easier to prove!
Mar5-06, 09:45 AM   #6
Recognitions:
Quote by rad0786
that is a huge leap. It contains an element of Q (actually it contains infintely many elements of Q), it doesn't contain Q.
It is an 'if then' statement already, however it is exactly the reverse of what you wrote.
Mar5-06, 09:53 AM   #7
Quote by matt grime
Oops, that was a hudge leap. But I got the idea that it contains an element of Q.
I could say that between any two real numbers in the interval A their is a rational number (As prooved in lecture), thus, their exsits a rational number in A
Quote by matt grime
So if I prove what I worte, then its as if I assume its an "if and only if statement" which would be an invalid assumption.
Mar5-06, 10:18 AM   #8
Recognitions:
Erm, you are free to prove the statement you made, however it doesn't at all answer the question you were asked. Rather than say 'it is as if I assume it is an if and only if statement', I would say you have just not proved what you were asked to prove. I don't know what you were assuming.
Mar5-06, 10:34 AM   #9
You are right.
Oh, what I was trying to say was, for example,
If it rains, then I'll watch TV
If I watch TV, then it rains.
These 2 statements don't mean the same thing.
But If I want to prove "it rains if and only if I watch TV"
Then ill have to prove
So for the question, I was trying to prove it the wrong way beacue it was easier, however, I can't do that.
So ill just have to prove "An accumulation point of a set S is either an interior point of S or a bounadry point of S" and NOT "If a point in S is either an interior point of S or a boundary point of S, then it is an acculumation point." :)
Mar5-06, 10:58 AM   #10
Recognitions:
Quote by rad0786
How did you manage to prove your version? It looks false to me.
Mar5-06, 11:14 AM   #11
Oh no.. i think im confusing you guys.. im Sorry for that.
I didnt prove it yet, I was just wondering if it would be valid to proove "If a point in S is either an interior point of S or a boundary point of S, then it is an acculumation point." INSTEAD of proving "An accumulation point of a set S is either an interior point of S or a bounadry point of S" ... Which i found out you can't do that
Sorry for the confusion.
Mar5-06, 11:33 AM   #12
Recognitions:
Quote by rad0786
I did understand this point. I'm just pointing out that the statement "If a point in S is either an interior point of S or a boundary point of S, then it is an acculumation point." is false, irregardless of the fact that it wouldn't solve your question. Your set S={2} will serve as a counter example, 2 is a boundary point yet not an accumulation point (at least not under the definition I'm used to, i.e. every neighbourood of 2 would need a point in S\{2}).
Mar5-06, 11:42 AM   #13
Ohhh okay! I see what you'r saying. That is true indeed! I learned now that I have to be very carefull when doing proofs like this ... and their is not to look for an easy way out.
Mar6-06, 06:14 PM   #14
Okay, I've spent all of yesterday and most of today on this same question. With very little progress.
Suppose [itex]a \in S'[/itex] (S' is the set of accumulation points). Then [itex]a \in (N^* (x,e) \cap S) \neq \emptyset [/itex] ... which means that [itex]a \in S[/itex]. Since [itex]a \in S[/itex], then a is either an interior point or a boundary point?
How does that sound? I feel like its not good.. but thats as far as I could get.
I tried breaking it up into cases, case1: S is open, case2: S is closed.... where case1 would mean its an interior point.
But this fails because i cannot come up with anything for case2
Anybody got any ideas please?
Thread Closed
Thread Tools
Similar Threads for: Topology (Boundary points, Interior Points, Closure, etc...)
Thread Forum Replies
Set of points equidistant from two points Calculus & Beyond Homework 1
help~find the interior, boundary, closure and accumulation points of the following. Calculus 5
glasses to fix near points and far points Introductory Physics Homework 4
boiling points, melting points and absorbed radiation Q's Introductory Physics Homework 0
set closure and interior points Calculus 3
