Solve Physics Problem 12a: Net Electric Field at y=2.1m
The problem involves calculating the net electric field at a point on the y-axis due to two point charges located on the x-axis. The charges are specified as 5 µC and 4 µC, positioned at distinct points along the x-axis. The objective is to determine the magnitude of the electric field at y = 2.1 m.
  • Participants discuss the need to consider the vector nature of electric fields due to the different distances and angles from the charges to the point of interest. There are attempts to calculate the electric fields from each charge and combine them vectorially. Some participants express confusion about the calculations and the resultant angle.
Multiple participants are actively engaging with the problem, sharing their calculations and questioning each other's approaches. There is a mix of interpretations regarding the resultant angle and the method for combining the electric fields. Some guidance has been offered on how to approach the vector addition of the fields.
Participants note discrepancies in their answers and express uncertainty about the correctness of their calculations. There is mention of a previous similar problem that may have influenced their understanding and approach.
mustang
Problem 12a.
Given:k_e=8.98755*10^9Nm^2/C^2.
A 5u_C point charge is on the x-axis at x=2.3m, and a 4u_C point charge is on the x-axis at x=3.3m.
Determine the magnitude of the net electric field at the point on the y-axis where y=2.1 m. In N/C.
Note: I been getting wrong answers from a problem that is bascially the same as problem 12a. Can someone show me the steps?
I think I know where you went wrong.
The charges are a different distance and angle from the point on the Y axis. This means that the fields are not in phase with each other. You have to sum the fields vectorally.
If you still can't get the answer, post your work.
I still don't get it. Here's my work:
q_1=5*10^-6
q_2=4*10^-6
y=2.1 m
Since 5u_C is on the x-axis with 4u_C the distance between them was 1m.
So I found my angle by tan-1(2.1/1)=64.53665494.
E_1=(8.99*10^9)(5*10^-6)/(2.1^2)=10192.74376
E_2=(8.99*10^9)(4*10^-6)/(2.32594067^2)=6646.950092
E_x,2 =(E_2)*cos64.53665494=2857.747052
E_y,2=-(E_2)*sin64.53665494=-6001.268809
E,x tot=2857.747052
E,y tot = 4191.474951
Etot=square root(2857.747052)^2+((4191.474951)^2=5072.985362N/C
55.74383949 degrees.
Ok I sort of understood what you were doing but not completely. I'll try to get the answer here.
field from the first charge:
[tex]E = \frac{kq}{d^2}[/tex]
[tex]E = \frac{(9x10^9)(5x10^-^6)}{\sqrt {2.3^2 + 2.1^2}}[/tex]
[tex]E = \frac{45000}{3.114}[/tex]
[tex]E = 14451[/tex]
field from second charge:
[tex]E = \frac{(9x10^9)(4x10^-^6)}{\sqrt{3.3^2 + 2.1^2}}[/tex]
[tex]E = \frac{36000}{3.9115}[/tex]
[tex]E = 9203.6[/tex]
Now to solve for the resultant I drew a triangle.
http://myfiles.dyndns.org/pictures/triangle.jpg
Where the 2 vectors meet, I drew a line left and one down to help show the angle for that intersection. Now here are the angles for each of the labels
angle A:
[tex]A = tan^-^1(\frac{2.1}{3.3})[/tex]
[tex]A = 32.47[/tex]
angle B is just 90
[tex]B = 90[/tex]
angle C:
[tex]C = tan^-^1(\frac{2.3}{2.1})[/tex]
[tex]C = 47.6[/tex]
The angle where the vectors meet is just the sum of those angles.
so the angle is 32.47 + 90 + 47.6 = 170 degrees
Now use the cosine law to find the resultant
[tex]C = \sqrt{A^2 + B^2 - 2ABcos(c)}[/tex]
[tex]C = \sqrt{14451^2 + 9203.6^2 - 2(14451)(9203.6)cos(170)}[/tex]
[tex]C = 23569[/tex]
And that's what I think the answer is.
So the magnitude of the net electric field at the point on the y-axis where y=2.1m is 23569 and the angle is 170.
6.6187*10^3 N/C
This is what I got when I retried it again. Is this right?
The angle for the resultant is not 170. 170 is the angle between the electric fields. You don't need to know the angle of the resultant, the question does not ask for it.
I'm just wondering what the angle of this electric field? Would I divide 14451 by 9203.6 and multiply that by tan-1 to get the angle.
If you wanted the angle of the resultant, you wouldn't do the vector triangle method like I did. What I probably would have done is find the angle for each field then break each field into x and y components. Add the x components together, add the y components together then solve for the resultant like it's a right angle triangle. From there, since you know the x and y components, you could just use tan to find the angle.
6.6187*10^3 N/C
My answer was 23569; that doesn't mean I'm right though.
and that this was problem 12a.
Can you post the other problem as well as the answer?
