| Thread Closed |
Solving modulus functions |
Share Thread | Thread Tools |
| Mar6-06, 07:00 AM | #1 |
I need to solve:
[tex]\left| 2x-3 \right| = 5 - x^2[/tex] I started by squaring the equation because modulus functions can only be positive and obtained: [tex]x^4 -14x^2 +12x +1 = 0[/tex] I haven't olved any quadnomial equations before, so I don't know where to start. Any help would be much appreciated. |
| Mar6-06, 07:28 AM | #2 |
Recognitions:
It'll help if you note that: |A| >= 0. So if you are saying that |A| = B, then is it obvious that B should be non-negative, too? Now if B is non-negative, and we have |A| = B, so that means: A = B, if A >= 0 A = -B, if A < 0, right? So all you have to do is to solve the system of equations: [tex]\left\{ \begin{array}{l} 5 - x ^ 2 \geq 0 \\ \left[ \begin{array}{l} 2x - 3 = 5 - x ^ 2 \\ 2x - 3 = x ^ 2 - 5 \end{array} \right. \end{array} \right.[/tex] Can you get it? :) |
| Mar6-06, 08:02 AM | #3 |
I get:
[tex]x\leq\sqrt{5}[/tex] Then for the first equation [itex]x=2[/itex] and [itex]x=-4[/itex]. And for the second; [itex]2\pm 2\sqrt{3}[/itex] but we must ignore the [itex]2 + 2\sqrt{3}[/itex] because it lies outside the inequality. Ive got three answers what have I done wrong? |
| Mar6-06, 08:08 AM | #4 |
Recognitions:
The split to the cases 2x-3=5-x^2 and 2x-3=x^2-5 had additional restrictions on x that came from the absolute value sign, you haven't taken this into account yet.
| Mar6-06, 08:12 AM | #5 |
Recognitions:
What you should get is: [tex]-\sqrt{5} \leq x \leq \sqrt{5}[/tex] However, -4 is not a valid solution, it's outside the range. Can you go from here? :) ------------ By the way, one can always check their answer by plugging the solution back to the equation. For example: x = 2 is one of the solution. So: |2x - 3| = |2 . 2 - 3| = 1 5 - x2 = 5 - 22 = 1. And hurray!!! 1 = 1. Can you get this? :) |
| Mar6-06, 08:17 AM | #6 |
Recognitions:
And if: 2x - 3 = -(5 - x2) = x2 - 5, then it's obvious that 2x - 3 <= 0. No? So one is enough, I think.
| Mar6-06, 08:17 AM | #7 |
Ahh yes, I remember the critical values now. It's along time since I've practised solving inequalities.
So [tex]x = \frac{2\pm 2\sqrt{3}}{2} \Rightarrow x = \pm\sqrt{3}[/tex] Both solutions lie with the inequality so the solutions are [itex] x=-4, x=-\sqrt{3},x = \sqrt{3}, x=2[/itex] Does that look ok? |
| Mar6-06, 08:20 AM | #8 |
Recognitions:
![]() It should read: [tex]x = 1 \pm \sqrt{3}[/tex] :) You'll have only 2 valid solutions left. Can you go from here? :) |
| Mar6-06, 08:28 AM | #9 |
O dear, does the lack of sleep show?
So the only valid solutions are: [tex]x=2[/tex] [tex]x=1-\sqrt{3}[/tex] Thank's very much for your help. |
| Mar6-06, 08:32 AM | #10 |
Recognitions:
![]() Congratulations, :)
| May20-10, 12:35 PM | #11 |
can i have solution of the Question if f(x) = 1-x/1+x,x>0 then f(f(x)) +f(f(1/x))
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solving modulus functions
| Solving Modulus inequalities | Calculus & Beyond Homework | 3 | ||
| Solving functions algebraically (cube roots) | Precalculus Mathematics Homework | 3 | ||
| Solving a System of Congruences with A Changing Modulus | Linear & Abstract Algebra | 3 | ||
| Solving inverse trig functions | Calculus | 2 | ||
| Youngs Modulus and Elastic Modulus | Introductory Physics Homework | 6 | ||
