Messed up somewhere in my integration
  • Thread starter Thread starter mr bob
    Integration
The discussion revolves around a problem involving integration in the context of motion, specifically dealing with the relationship between velocity and position of a particle. The original poster, Bob, presents a differential equation and attempts to integrate it to find the time as a function of position.
  • Bob attempts to integrate a differential equation relating velocity and position but expresses uncertainty about the correctness of his integration steps. Participants question the handling of constants during integration and the correctness of signs in the equations.
Participants are actively engaging with Bob's integration process, offering suggestions for checking constants and signs. There is a collaborative effort to clarify the integration steps, but no consensus has been reached on the final outcome or resolution of the problem.
Bob indicates that he is struggling with the integration process and has made several posts seeking clarification, suggesting a potential lack of confidence in his mathematical skills. There are also hints of typographical errors affecting the clarity of the discussion.
mr bob
[tex]\frac{dv}{dt}= -x^{-3}[/tex]
when t=0, the particle is at rest with x=1
Therefore by integrating i get
[tex]v = \sqrt(x^-2 - 1)[/tex]
[tex]\frac{dx}{dt}= \sqrt(\frac{1 - x^2}{x^2})[/tex]
[tex]dx\frac{x}{(/sqrt(1 - x^2))} = dt[/tex]
[tex]-\sqrt(1 - x^2) = t + C[/tex]
[tex]C=-1[/tex]
Therefore:-
[tex]t = 1 - \sqrt(1 - x^2)[/tex]
However i can't get the answer [tex]t = \sqrt(15)[/tex] when [tex]x = 1/4[/tex]. I think i messed up somewhere in my integration. I would really appreciate any help with this.
Thank you,
Bob
Did you add the constants well after integration? If you show your works of integration it would be easy to check.
[tex]\frac{1}{2}v^2 = \frac{x^-2}{2} + C[/tex]
As at rest when x = 1, v = 0
then C = -1
Then i continue to integrate as above.
You didn't multiply C by 2 in the third step.
But isn't C just a constant. Which wouldn't matter if i multiplied it by 2 or not.
Sorry it was a typo. I preesed enter by mistake.
Check the sign at t = -(1 - x^2)^-2. It is correct till there.
Thank you very much. My maths has been pretty bad over the last couple of days (you can tell by the number of posts).
By thw way, you should use \sqrt{} rather than \sqrt()
  • · Replies 105 ·
13K
  • · Replies 22 ·
