Subspaces in R4: Get Started & Understand Now
  • Thread starter Thread starter Pengwuino
    Subspaces
The discussion revolves around determining whether a specific set of vectors in R4, defined by the equation x1 + x3 = x2 + x4, constitutes a subspace. Participants express confusion regarding the concepts of vector spaces and the necessary axioms to verify subspace properties.
  • Participants discuss the axioms that need to be checked for subspace verification, including vector addition, scalar multiplication, and the presence of the zero vector. There are attempts to express the condition in different forms and to explore how to demonstrate that the sum of two vectors in the set remains in the set.
Several participants are actively engaging with the problem, offering insights into how to approach the verification of subspace properties. There is a mix of attempts to clarify definitions and to explore the implications of the given condition, but no consensus has been reached on a definitive method or conclusion.
Some participants express frustration with the complexity of the problem and suggest focusing on variables rather than specific numbers. There is also mention of ignoring certain comments that may not contribute constructively to the discussion.
Pengwuino
I'm so lost!
1. W is the set of all vectors in R4 such that x1 + x3 = x2 + x4. Is W a subspace of R4 and Why?
How do i get started here? I'm thoroughly confused on this whole idea of vector spaces and such.
What are the axioms you need to check, and what can you verify and how?
I find looking at the definitions helpful in such a case.
So far we're looking at vector addition, scalar multiplication and the zero vector. Plugging in 0,0,0,0 produces a vector that is in the set. I'm not sure how to show vector addition however. Do i need to turn that equation into a function x1= x2 + x4 - x3?
What you need to do is to treat
"(a, b, c, d) is in W"
as being synonymous with
"a + c = b + d"
Can i set a new vector equal to like (y1 + y3 = y2 + y4) and add the equations?
No. You need to treat
"a + c = b + d"
So what, abstractly speaking, are you trying to show?
Take two elements that satisfy the condition, add them, does the result satisfy the condition?
suppose i wanted to show that the subset V of R^2 defined by (x,y) in V if x=0, then let (x,y) and (s,t) be in V, the sum is (x+s,y+t), now is x+s zero when x and s are zero?
"a + c = b + d"
Ok so how can I show that they add up using two different vectors? I know for example, (1,3,4,2) are in W but how do i go about showing that all such vectors satisify vector addition and multiplication?
I guess I'm trying to show that every vector that follows a + c = b + d is a vector in W. Is that right?
If I pick v = (1, 3, 4, 2) and u = ( 3, 6, 5, 2), they add up to be (4, 9, 9, 4) which is also in the set. I can also do cv, c being say, -3, to get cv = ( -3, -9, -12, -6) which is also in the set. How can i show that it works for all numbers?
Formally, we have W is defined by
[tex]W=\left\{ (x_1,x_2,x_3,x_4)\in\mathbb{R}^4 : x_1 + x_3 = x_2 + x_4 \right\}[/tex]
The requirement [itex]x_1 + x_3 = x_2 + x_4[/itex] may be written as [itex]x_4 = x_1 - x_2 + x_3[/itex] and notice how once [itex]x_1, x_2, x_3[/itex] are chosen, [itex]x_4[/itex] is determined, and so it would seem we only need three parameters to express points in W...
If you need more, post on that wise.
don't use numbers...use variables
you are given a condition x1+x3=x2+x4, someone above
said look at (a,b,c,d) and you yourself posted can i do x1=...
NOW combine those 2 concepts to get a general vector satisfying your given condition. Note you should ask yourself how many unknowns should remain in your general vector
i am going to state categorically, and I'm sorry to do so, that you should ignore benorin.
it's very easy, so stop making it difficult.
let's do my example, since I refuse to answer your homework,
Define W in R^2 by (x,y) is in W if and only if x=0.let's show it is a subspace.
1. (0,0) is in W, clearly since the first coordinate is zero
2. if (x,y) and (u,v) are in W the (x+u,y+v) is in W since x+u=0 because x=0 and u=0
3. if (x,y) is in W then so is t(x,y)=(tx,ty) since x=0 implies tx=0
and we are done.
so how about it, now?
You see how to do it?
If [tex]\forall\alpha , \beta\in\mathbb{R},x,y\in W\Rightarrow (\alpha x+\beta y) \in W ,[/tex] then W is a subspace. That's it. Simple.
Parts (1), (2), and (3) of your test correspond to the cases [tex]\alpha=\beta=0, \alpha=\beta=1, \mbox{ and }\alpha=t,\beta=0,[/tex] respectfully.
i meant it was this comment that should be ignored. i don't see what choosing and determing things has to do with proving its a subspace
I was attempting to lead to the representation of vectors in W as vectors of the form (x1,x2,x3,x1-x2+x3) is all.
  • · Replies 23 ·
