Calculating Bolometric Correction for Cepheid Variables
  • Context: Graduate
  • Thread starter Thread starter toph
    Correction
The discussion centers on the calculation of bolometric correction for Cepheid variables, particularly in relation to their periods. Participants explore the feasibility of deriving absolute visual magnitudes from limited information, specifically the period of the Cepheid variables, and the implications of spectral classification on these calculations.
  • One participant questions whether bolometric correction can be calculated solely from the period of a Cepheid variable, suggesting the use of a period-luminosity relationship to derive luminosity and bolometric magnitude.
  • Another participant argues that photon counts at specific temperatures are necessary for calculating bolometric correction, highlighting the limitations of detectors and potential biases in measurements.
  • A different participant emphasizes that knowing only the period is insufficient for accurate calculations, as the classification of Cepheid variables (Population I vs. Population II) significantly affects their properties and the derived values.
  • One participant notes the historical context of early measurements of Cepheids and their impact on distance calculations, pointing out the errors due to misclassification.
  • There is a request for methods to estimate absolute visual magnitude from the periods of Cepheid variables, specifically for stars with periods of 3 and 60 days, but uncertainty remains regarding the spectral types necessary for accurate estimation.
Participants express differing views on the sufficiency of period alone for calculating bolometric correction and absolute visual magnitude, indicating that multiple competing perspectives exist regarding the necessary information and methods.
Limitations include the dependence on spectral classification for accurate calculations and the unresolved nature of how to estimate absolute visual magnitude from period alone without additional data.
toph
hi
can the bolometric correction be calculated if all i know of a cepheid variables properties are its period? for example, if the cepheid variable has a period of 3 days i can use a period-luminosity relationship to calculate the luminosity, from here i can then calculate the bolometric magnitude. my question really is this, can i then calculate the bolometric correction required to find the absolute visual magnitude? or is there an easier way to get to the absolute visual magnitude from just the information given.
hopefully some one can point me in the right direction, thanks
(this is a question that has come up in one of the books i am reading, so if it is in the wrong forum i appologies)
Astronomy news on Phys.org
As far as I know, you need to have photon counts for specific temperatures for the stars that you want to calculate the correction for. This is basically because at a given temperature, there is a photon count we expect to see and a photon count we actually see, the difference is, in part, due to the fact that the detector we use is not sensitive to all wavelengths.
The formula I'm aware of regarding bolometric correction is:
[tex] <br /> BC = 2.5*\log(\frac{N_1}{N_2}) - 10\log(\frac{T_1}{T_2}) - BC_2<br /> [/tex]
where Ni's are photon counts and T's are temperatures. BC2 is the bolometric correction for the second star.
Though, I'm not sure if you need to, but there are other factors worth metioning. For example, the detector used to find the counts above is likely to not only not be sensitive to all wavelengths but is also likely to unintentionally incorporate a bias - it will not be equally sensitive to all wavelengths. There are also other factors such as - are your photon counts subject to interstellar absorption? Not sure if any of this is relevant.
toph said:
hi
For a Cepheid, if you know nothing but the period, you wouldn't be able to use the period-luminosity relationship to get bolometric magnitude or much of anything, including distance. This is because there are "classical cepheids" of Population I with periods of 2 to 40 days and "W-Virginis Stars" which are cepheids of Population II.
For a given period, the W-Virginis stars are about 1.5 to 2.0 magnitudes less than classical cepheids, so you would at least need a spectral analysis to determine if the star is a Pop I or Pop II cepheid. It was on this particular point that the early (1920's I think) measurements to the Andromeda galaxy showed ~1.1 million Ly when it is actually ~2.2-2.5 million Ly. The first cepheid measurements and period-luminosity relationships were done only on classical cepheids, hence the original error(s).
thank you
that kind of makes sense, i have seen several tables showing the bolometric correction, these vary with spectral type so i can see why the temperature would be important. Do you then know of any way to estimate the absolute visual magnitude from just the peiod of a cepheid variables? I am particularly interested in two stars with periods of 3 and 60 days respectively.
toph said:
thank you
No I don't, without knowing the spectral type. The W-Virginis (Pop II) cepheids cluster around 18 day periods but some are as short as ~2 days. See:
http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1991AJ...101.1795M&amp;data_type=PDF_HIGH&amp;type=PRINTER&amp;filetype=.pdf
But, it might be safe to assume a 60 day period would be a classical (Pop I) cepheid due to that long period. I'm not sure, but I don't know if any Pop II's with long periods as 60 days.
  • · Replies 40 ·
12K
