Real Analysis: Convergence of Trigonometric Series on R
The discussion revolves around the convergence of a trigonometric series defined as 1 + Σ((1/(2^k))coskx + (1/(2^k))sinkx) for each x in the real numbers. Participants are tasked with demonstrating the convergence of the series and the continuity of its sum function f(x).
  • Participants explore the relationship between the terms of the series and convergence criteria, with some attempting to apply comparison tests. There are questions regarding the correctness of trigonometric identities and the implications of terms tending to zero on convergence.
The discussion is active, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the application of convergence tests and the importance of accurate trigonometric identities.
There are indications of confusion regarding trigonometric identities and convergence principles, with participants questioning assumptions made in earlier posts. The original poster's approach to convergence is being critically examined.
annastm
Consider the series
1+ Σ((1/(2^k))coskx + (1/(2^k))sinkx)
(a) Show that series converges for each x in R.
(b) Call the sum of the series f(x) and show that f is continuous on R = real numbers
My thoughts:
From trig => cos + sin = 1. So, is it something like
|coskx + sinkx| / |2^k| < or = (in particular = ) 1/2^k = M. Then since ΣM = Σ(1/2^k) converges (since 1/2^n approaches 0, even though it never attains it) Thus the given series converges uniformly and therefore converges. Adding 1 will not change the fact that it converges.
This is your problem. What have you done on it?
This is what I've done:
My thoughts:
Can you please correct me?
My thoughts:
Well, for starters, [tex]cos\theta+sin\theta \neq 1[/tex]. What you are looking for is [tex]cos^2\theta+sin^2\theta=1[/tex].
-Dan
And nor is it even true that cos(x)+sin(x)<1 for all x, but one can do something with the abs value, or one can just appeal to any of the comparison tests.
Further, when you say .
"Then since ΣM = Σ(1/2^k) converges (since 1/2^n approaches 0, even though it never attains it)"
please tell me that you don't think the terms tend to zero implies the sum converges. If there is exactly one result in analysis that is hammered home ad nauseum it is that this is is clearly false as can be seen just from trying to sum 1/n the simplest series whose terms tend to zero.
