Is Seeing a Black Hole Possible?
  • Context: High School
  • Thread starter Thread starter Moore1879
    Black hole Hole
The discussion revolves around the question of whether black holes can be seen, exploring various theoretical and observational perspectives. Participants delve into concepts related to detection methods, the nature of black holes, and the implications of visibility in different contexts, including philosophical considerations.
  • Some participants suggest that black holes cannot be seen directly, as they absorb all light, but their presence can be inferred through the behavior of surrounding matter, such as accretion disks.
  • Others propose that it may be possible to detect black holes indirectly by observing phenomena like Einstein rings or gravitational lensing effects when a black hole is positioned between an observer and a distant star.
  • A participant mentions ongoing work on telescopes that could potentially visualize the event horizon of a black hole, though skepticism is expressed regarding the feasibility of this due to the size and obscuring materials around black holes.
  • There is a discussion about the visibility of smaller black holes, with some claiming they could emit more Hawking radiation, which might be detectable, while others point out that human eyes cannot perceive X-rays or Hawking radiation directly.
  • One participant raises a philosophical question about the nature of seeing and whether it is possible to "see" blackness, suggesting that the definition of seeing could render the discussion unscientific.
Participants express a range of views on the visibility of black holes, with no consensus reached. Some agree on indirect detection methods, while others challenge the feasibility of certain proposed methods and the definitions of visibility.
Limitations include the dependence on definitions of visibility, the challenges of detecting black holes against cosmic backgrounds, and unresolved questions about the nature of radiation emitted by black holes.
This discussion may be of interest to those exploring astrophysics, cosmology, and the philosophical implications of observation in science.
Is it possible for the human eye to see a black hole?
  • Yes
    Votes: 2 20.0%
  • No
    Votes: 6 60.0%
  • Yes, but only with those really cool 3-D Movie Glasses
    Votes: 1 10.0%
  • I don't know
    Votes: 1 10.0%
  • Total voters
  • Poll closed .
Moore1879
I am just curious as to what the generally accepted ideas are about black holes.
Astronomy news on Phys.org
I would say no because that would totally contradict what they are saying about black holes.
The only way to detect them (from what I know) is to find things moving about something that which we can not see, and that observing this, the object must be really massive.
You can't see the surface of a black hole, of course; it absorbs all light which hits it.
You can however, see the accretion disk, the ring of in-falling matter which commonly orbits black holes, spiraling inward towards the hole. As material gets closer and closer to the black hole, the tidal forces become more and more severe. The squeezing and stretching generates a lot of heat, and it's common for matter in an accretion disk to be so hot it's glowing in X-rays!
This is actually how quasars are detected, and quasars are some of the most distant objects known in the universe. Quasars are hypothesized to contain active, supermassive black holes, and we see the intense radiation from their accretion disks billions of light-years away. No other known process can generate such intense radiation.
- Warren
:confused: :confused:
I don't understand what you mean with this option:confused:
That's probably a joke, scott1.
This depends on what you mean by "see".
I heard there is work being done on a telescope that can actually see the event horizon of a black hole due to the fact that it would be darker than the surrounding gas/dust: A "hole" in a nebula.
It would take rather special circumstances to see a black hole.
One possibility is that the black hole could come between you and a star, in which case you might see Einstein rings.
Another interesting possiblity is that if you had a really bright light (or a laser beam), you could also "see" light bent through an angle of 360, 720, 1080, etc. degrees if you shone the light at the black hole. But it would probably be difficult to get a light bright enough (or a laser with enough intensity) to actually pull this trick off.
It would be much more likely that you would see the accretion disk around the hole, as others have remarked.
To me, this seems very implausible. Betelgeuse is a close supergiant star whose disk astronomers are just able to resolve. If my calculations are correct, the disk of the supermassive black hole at the centre of our galaxy subtends an anlgle much smaller than the disk of Betelgeuse. Also, the optical image of this supermassive black hole would be completely blocked by dust and other stuff. The situation for a 10 solar mass black hole formed from stellar collapse seems even more hopeless.
Regards,
George
Can a black hole be seen?
Yes, if the black hole is small enough.
Regards,
George
Regards,
George
Can you explain why if a black hole is small enough it can be seen?
Smaller black holes emit more Hawking radiation, which is probably the closest one gets to directly "seeing" the black hole. If you include radiation from accretion, however, the big black holes have the potential to be much brighter (due to a larger Eddington luminosity).
i don't think that a human eye can see xrays or hawking radiation
You can always see a black hole by the gravitational distortion that it causes to the background of stars even if it is not accreting or so small that it radiates visible light but because they are so small (stellar mass holes are only a few Km across) you have to be very close before you could resolve it as a disc with the naked eye even monster holes in the middle of galaxies are only as big as the solar system so again you probably have to be within a light year or so to see a disc.
I have seen simulations of this on video but don't know if any are available on the web
You can see hawking radiation if it's in the visible spectrum. :-p
This is a purely philosophical question. Can you see blackness? Is seeing actually detecting light with your eyes, or more generally, taking in information with your eyes. It all depends on how you want to define it, making this thread unscientific and pointless.
  • · Replies 40 ·
  • · Replies 20 ·
