Magnetic Fields and Maximum Current
The maximum current that a wire can carry in an experiment measuring the Earth's magnetic field (4.5 x 10-5 T) at a distance of 0.60 m is calculated using the formula B = (4π x 10-7)I / (2πR). The initial calculation of 135 A was incorrect due to misunderstanding the +/- 1% measurement error. Correctly applying the 1% tolerance to the magnetic field value leads to the accurate determination of the maximum current.
  • Understanding of magnetic fields and their measurement
  • Familiarity with the formula B = (4π x 10-7)I / (2πR)
  • Knowledge of percentage error calculations
  • Basic physics concepts related to electromagnetism
  • Study the effects of distance on magnetic field strength
  • Learn about the implications of measurement error in experimental physics
  • Explore the principles of electromagnetism in greater detail
  • Investigate other applications of the Biot-Savart Law
Physics students, experimental researchers, and educators looking to deepen their understanding of magnetic fields and current measurements in electromagnetism.
Mehta29
Hey guys I'm new here and needless to say I am completely lost...
well here is the problem...
What is the maximum current that a wire can carry if an experimenter is performing an experiment 0.60 m away that deals with the Earth's magnetic field (4.5*10-5 T), which she wishes to measure to +/- 1 percent?
i thought I could just plug the #'s given into
B = (4pi*10^-7)I / (2(pi)R)
and i ended up with 135 A...which seemed muuuuuuuuch too high...and assumably was wrong...
(4.5*10^-5) = (4pi*10^-7)I / 2(pi)(.6??)
It would be greatly appreciated if i could get this help tonight...but I just want to understand what I'm doing wrong for the most part...
well i found the error of my ways...
the whole +/- 1% threw me off...
i get the right answer if i multiply by the magnetic field by 1% and then re-plug everything in...
hopefully this helps someone in the future...
  • · Replies 23 ·
