Geodesics in schwarzschild solution
The discussion focuses on the Schwarzschild solution in general relativity, specifically the equations of motion for a particle falling into a black hole. It establishes that the time independence of the Schwarzschild metric leads to a constant four-velocity component, u_0, which is derived as u_0 = sqrt(1 - 2M/R). The conversation highlights the challenges in proving this constancy through the geodesic equations, resulting in complex coupled differential equations. The participants also discuss the implications of a Lagrangian being independent of certain generalized coordinates, leading to conserved quantities in the context of geodesic motion.
  • Understanding of Schwarzschild metric in general relativity
  • Familiarity with geodesic equations and their derivations
  • Knowledge of Lagrangian mechanics and conserved quantities
  • Basic proficiency in differential equations
  • Study the derivation of the Schwarzschild metric in general relativity
  • Learn about the geodesic equation and its applications in curved spacetime
  • Explore the concept of Killing vectors and their role in conservation laws
  • Investigate the Lagrangian approach to classical mechanics and its implications in general relativity
Students and researchers in theoretical physics, particularly those focusing on general relativity, black hole dynamics, and the mathematical formulation of geodesics.
Pietjuh
Hello everybody,
I was studying the lecture notes about the schwarzschild solution for general relativity. In a particular example they calculate the equations of motion of a particle falling straight into a black hole. But there are some things about the calculation I really don't get.
First of all they say that because the schwarzschild metric is time independent, so dg/dt = 0 => u_0 = const. Then they show that by using the initial conditions r = R and tau = 0 and t = 0 coincide, that u_0 equals to sqrt( g_00(R) ) = sqrt(1 - 2M/R).
I've tried to prove the constancy of u_0 from the geodesic equation, but all I got were some nasty coupled differential equations.
Somehow it is true that constancy of metric in one component direction implies that the four-velocity in that component is constant. But I don't see why that is true. And how can you show from this, that this means that u_0 = sqrt(1-2M/r) ?
Pietjuh said:
I've tried to prove the constancy of u_0 from the geodesic equation, but all I got were some nasty coupled differential equations. ... And how can you show from this, that this means that u_0 = sqrt(1-2M/r) ?
Are you familiar with the Lagrangian approach to geodesic motion in GR. What happens when a Lagrangian is independent of one of the generalized coordinates?
In this case, the conserved quantity gives
[tex]\left(1 - \frac{2M}{r} \right) \frac{dt}{d\tau} = \left(1 - \frac{2M}{R} \right)[/tex].
Take a look at https://www.physicsforums.com/showpost.php?p=621802&postcount=32" of mine. Note that I forgot to "divide" by the [itex]d\tau[/itex]'s in the definition of the Lagrangian.
Regards,
George
Pietjuh said:
Hello everybody,
Oops, I'm afraid that I totally missed the point on my first response :-(. So I've deleted it and will start over.
Let us suppose that we have some paramaterized infalling trajectory [itex]r(\tau), t(\tau)[/itex] for a particle falling straight into the black hole.
The "messy diffeqs" you get via the geodesic equations should be, omitting all the zero Christoffel symbols should be eq1 and eq2 below.
eq1:
[tex] \frac{d^2 t}{d \tau^2} + 2 \Gamma^t{}_{rt} \frac{dt}{d\tau}\frac{dr}{d\tau} = 0[/tex]
eq2:
[tex] \frac{d^2 r}{d \tau^2} + \Gamma^r{}_{rr} \frac{dr}{d\tau}\frac{dr}{d\tau} + \Gamma^r{}_{tt} \frac{dt}{d\tau}\frac{dt}{d\tau} = 0[/tex]
Now, consider the equation
eq3:
[tex] g00(r(\tau)) \, \frac{dt}{d\tau} = C[/tex]
where C is some constant. We can rewrite this as
[tex] \frac{d g00(r)}{dr} \, \frac{dr}{d\tau} \frac{dt}{d\tau} + g00(r) \,\frac{dt^2}{d\tau^2} = 0[/tex]
by making use of the fact that [itex]dC/d\tau[/itex] = 0 and applying the chain rule for differentiation.
Normalizing the coefficeint for the second derivative by dividing by g00, we get
[tex] \frac{dt^2}{d\tau^2} + \frac {\frac{d g00}{dr}} {g00} \frac{dt}{d\tau} \frac{dr}{d\tau} = 0[/tex]
When we substitute g00(r) = -1 + 2m/r and for [itex]\Gamma^t{}_{rt}[/itex], we find then that the messy-looking eq1 is just our eq3.
eq3 didn't really spring out of thin air, it can be motivated in several ways - see George's posts, or read up on "Killing vectors". Meanwhile, it's good to know that eq3 is really just one of the geodesic equations (i.e eq1) in a simpler form.
If you like, you can use eq3 to eliminate [itex]dt/d\tau[/itex] entirely from eq2, leaving you a differential equation for r.
  • · Replies 27 ·
