Tangent Line Equation for f(x) = √x+1 Parallel to x-6y+4=0
The discussion revolves around finding the equation of a tangent line to the function f(x) = √(x+1) that is parallel to the line represented by the equation x - 6y + 4 = 0. Participants are exploring the relationship between the derivative of the function and the slope of the given line.
  • Participants discuss the calculation of the derivative of the function and its significance in finding the tangent line. There are questions about how to proceed after finding the derivative, particularly in relation to the slope of the given line. Some participants suggest rearranging the line's equation to identify its slope.
The discussion includes attempts to clarify the derivative and its application to find the tangent line. Some participants have provided guidance on how to equate the derivative to the slope of the line, while others have pointed out potential misunderstandings in notation and expression. There is an ongoing exploration of the problem without a clear consensus on the next steps.
Participants are working under the constraints of a homework assignment, which may limit the information available or the methods they can use. There is also a focus on ensuring clarity in mathematical notation and expressions.
Christina-
Question: Find an equation of the straight line that is tangent to the graph of f(x) = √x+1[/color] and parallel to x-6y+4=0[/color].
I've found f`(x).
When I write lim, assume "h->0" (as h approaches 0) is beneath it. I'd like to use LaTex to show you, but it seems too confusing to figure out.
f`(x)=lim f(x+h) - f(x) / h
f`(x)=lim √x+h+1 - √x+1 / h x √x+h+1 + √x+1 / √x+h+1 + √x+1
f`(x)=lim x+h+1-x-1 / h(√x+h+1 + √x+1)
f`(x)=lim 1 / h(√x+h+1 + √x+1)
f`(x)= 1 / 2(√x+1)
So that's f`(x). The problem is, I'm not sure where to go from here. I'm trying to find the equation of the line, and it has to be parallel to x-6y+4=0. Usually when I do a question like this, I'm given the point, but what do you do when you're given a line parallel to the tangent?
Try re-arranging [itex]x - 6y + 4 = 0[/itex] into the form [itex]y = mx + c[/itex]. Does that give you any ideas? :smile:
You did the most difficult, i.e, find f'(x).
Now, you should find the point of the function where the derivative is equal to the slope of the given straight line.
But first we need to find the slope or gradient of the straight line.
x - 6y + 4 = 0 <=>
y = x/6 + 2/3
m = 1/6, because the equation of a straight line is y = mx + c (the constant m is often called the slope or gradient while c is the y-intercept)*
Then, we resolve the following equation:
1/6 = 1 / 2(√x+1)
I won't resolve it, since you have shown that you are able to do it. If you have difficulties resort to the calculator and intersect the functions y = 1 / 2(√x+1) and y = 1/6.
Hope I could help.
* To remind:
See- http://en.wikipedia.org/wiki/Linear_function
notation
Hi:
In the interest of effective communication, I highly recommend the use of grouping symblos. The derivative of f(x) = √x+1, for instance, is not 1 / 2(√x+1). Rather, f '(x) = 1/(2√(x)). That said, I assume that you mean f(x) =√(x+1), in which case f '(x) = 1 / [2√(x+1)]. Now set this expression equal to 1/6 and you are in business. As you have it, i.e., 1/6 = 1 / 2(√x+1), the variable stands alone within the radical. Moreover, you have expressed (√x+1) as a numerator rather than a denominator. By bracketing as [2(√x+1)], the reader understands your intent to place the entire expression beneath the fraction bar.
Regards,
Rich B.
Aha, that makes perfect sense. I probably should have thought it out more. I just worked out the answer using your tips and it shows to be correct.
Thanks for the help guys, and I'll keep that in mind Rich. :)
  • · Replies 21 ·
