Double-slit experiment of Young
The discussion revolves around the double-slit experiment, specifically examining the interference patterns produced when two monochromatic light sources with different wavelengths are used. The original poster is curious about the resulting light regions on the screen when the interference patterns overlap.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster questions how the interference patterns from two different wavelengths will interact, particularly when a bright region from one pattern coincides with a dark region from another. Other participants inquire about the definition of "light regions" and seek clarification on what is meant by the number of light regions.
The discussion is ongoing, with participants exploring various interpretations of the problem. Some have offered insights into the nature of the interference patterns and the effects of using different wavelengths, while others are seeking further clarification on specific terms and concepts.
There is a mention of a diagram that may assist in visualizing the problem, and the original poster expresses uncertainty about their understanding of the experiment, indicating a learning process in progress.
ntk
What will we see on the screen in double-slit experiment if I use two radiation have wavelength l_1 and l_2 . I know there will be two systems of interference fringe, call I and II. But what if one light region of I is coincident one dark region of II ?
And then how many light regions do we see on the screen ?
Have to say that I've never do this experiment :frown:
Is it a very stuppid question ?
Very interesting question. It is investigations like these that teach us more about nature. The double slit experiment is basically an interaction between matter (the double slit) and photons (the monochromatic light). Investigations of such seems to indicate that the photons motion is determined by the slits, that is where the photon diffracted is determined by the presence of the slits. The statistical distribution of the photons in the pattern depends on the wavelength and the distance between the slits.
Actually, if white light, which contains all the wavelengths of the spectrum, is shined at a set of double slits, you will see all of the colors on the screen(behind the slits) because each color(wavelength) is strongest at a different distance from the center.
Thank you very much.
Actually, the problem i have to solve is to determine number of light regions if i use two monochromatic lights in the double-slit experiment
What do you mean by the number of light regions? Bright bands per unit distance?
Use the diagram here :
http://www.physics.northwestern.edu/ugrad/vpl/optics/diffraction.html"
Should help you sort it out.
  • · Replies 34 ·
