Finding Rate of Change for Water Level in a Trough
  • Thread starter Thread starter answerseeker
    Change
The problem involves a trough with a triangular cross-section, specifically an isosceles triangle, and seeks to determine the rate of change of the water level as the trough is filled with water at a specified rate. The subject area is related to calculus and rates of change, particularly in the context of volume and geometry.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the correct formula for the volume of a triangular prism and the relationship between the dimensions of the triangle and the water level. Questions arise regarding the transition from a rectangular volume formula to one appropriate for a triangular cross-section.
Participants are exploring the correct geometric interpretation of the trough's volume. Some guidance has been offered regarding the appropriate formula for the volume of a triangular prism, and there seems to be a growing understanding of the relationship between the triangle's area and the volume calculation.
There is a noted confusion regarding the transition from rectangular to triangular volume calculations, and participants are working through the implications of the triangular cross-section on the volume formula. The original poster's notes are also referenced, indicating potential discrepancies in understanding.
answerseeker
A trough is 10 ft long and its ends have the shape of isosceles triangles that are 3ft across at the top and have a height of 1ft. if the trough is filled with water at a rate of 12ft^3/min, how fast does the water level rise when the water is 6inches deep?
so far i have: dv/dt= 12ft^3/min and need to find dh/dt.
V= base* height*length ? where length=10 ft.
what i don't understand is how come in my notes, the next step is that b becomes 0.5*b*h??
I have no way to help you with what is written in your notes. But...
The expression:
V= b*h*L
Gives the volume of a solid with a rectangular cross section. You have a solid with a triangular cross section so the the expression
V = .5*b*h*L
Would be correct.
can you complete the problem from there?
V= base*height*length for a RECTANGULAR trough. This is TRIANGULAR. The area of a triangle is 0.5*b*h.
I think I get it now. since it's a triangular prism, you take the area of the triangle and multiply it by the base of the rectangle. I think that's correct now.
  • · Replies 24 ·
10K
13K
