Copper Reflectivity: What Thickness is Necessary?
  • Thread starter Thread starter sachi
    Copper
The necessary thickness of copper to achieve optimal optical reflectivity is determined to be approximately ten times the skin depth. This conclusion is supported by the relationship between power dissipation and the skin depth, where the power dissipated per unit area is calculated using the formula (H^2)/2sigma*delta, with sigma representing conductivity and delta as the skin depth. Despite initial contradictions regarding the depth's impact on reflectivity, it is established that a highly polished surface finish significantly influences the amount of reflected optical energy. Ultimately, while some optical energy is transmitted and absorbed at thinner layers, thicker copper layers ensure complete reflection with no transmission.
  • Understanding of skin depth in conductive materials
  • Familiarity with optical reflectivity principles
  • Knowledge of the Poynting vector and its application in electromagnetic theory
  • Basic concepts of conductivity and its role in energy dissipation
  • Research the concept of skin depth in metals and its implications for reflectivity
  • Explore the effects of surface finish on optical reflectivity in conductive materials
  • Study the Poynting vector and its relevance in power dissipation calculations
  • Investigate the relationship between conductivity and optical properties in metals
Physicists, materials scientists, and engineers involved in optical applications, particularly those focusing on the reflectivity of conductive materials like copper.
sachi
We have a question that asks us what thickness of copper is necessary to achieve optical reflectivity. I know that the answer is just basically several times the skin depth (says 10 times). the only problem is that this contradicts a previous result that I've seen. We can prove that when a wave is incident on a metallic surface that the power dissipated per unit surface area is equal to (H^2)/2sigma*delta
where sigma is the conductivity and delta is the skin depth. We get this by integrating the poynting vector at z=0. This seems to suggest that the energy reflected from the surface of the conductor is independent of the depth of the copper, so surely it shouldn't matter thow thick the actual layer of copper is?
thanks for your help.
It seems that the surface finish will have a large effect on the amount of reflected optical energy. But assuming that the surface is highly polished, then maybe the two effects that you mention are not completely at odds. Only some of the optical energy will be reflected, regardless of how many skin depths deep the copper is. If the copper is only 1 skin depth thick, then some of the optical energy gets transmitted, some gets absorbed, and some gets reflected. If the copper is many skin depths thick, then none gets transmitted, some gets absorbed and some gets reflected. Can you reconcile the amount absorbed with the amount reflected?
  • · Replies 26 ·
  • · Replies 0 ·
  • · Replies 46 ·
