Is the Differential Cross Section Truly a Ratio of Differentials?
  • Context: Graduate
  • Thread starter Thread starter Norman
    Cross
The differential cross section, represented as dσ/dΩ, is not a ratio of differentials but rather a derivative that describes the cross section as a function of solid angle. The total cross section is a singular value derived from integrating the differential cross section over a specified range. The argument presented highlights that the total cross section is a number obtained from experimental data, such as particle counts from events like pp→pp. The discussion clarifies that the concept of a ratio of differentials is a misunderstanding, as the differential cross section is fundamentally a derivative, not a simple ratio.
  • Understanding of differential calculus and derivatives
  • Familiarity with particle physics terminology, particularly cross sections
  • Knowledge of solid angles in physics
  • Experience with experimental data analysis in high-energy physics
  • Research the mathematical definition of cross sections in particle physics
  • Study the concept of derivatives in the context of physical measurements
  • Explore the role of detectors in particle physics experiments and their impact on data accuracy
  • Learn about the integration of differential cross sections to obtain total cross sections
This discussion is beneficial for graduate students in physics, particle physicists, and researchers involved in experimental physics who seek to deepen their understanding of cross section measurements and their mathematical foundations.
Norman
Hello all,
I have a fellow grad student who is convinced that the differential cross section:
[tex]\frac{d\sigma}{d\Omega}[/tex]
is truly a ratio of differentials. That is you have an infinitesimal cross section divided by an infinitesimal solid angle.
I contend that when we write
we really mean
[tex]\sigma(\Omega)[/tex] and that we only call it the differential cross section because the integral of the differential cross section over the physical range of the variable gives the total cross section.
I stated this along with the fact that the total cross section is simply a number. You sample an event (lets say pp->pp is the event in question) at different energies and record the number of particles that come out of the reaction at the energy. This gives you a number.
The derivative of the number with respect to any variable is zero. So the differential cross section- is not the derivative of the cross section.
He contends this is not true because when you do the "experiment" you have a finite width detector and this smears out the solid angle so it is no longer an infinitesimal.
Can anyone find a very clear discussion somewhere about this fact? Or maybe present one? Or am I simply wrong and it truly can be thought of as a ratio of differentials?
Thanks,
Ryan
Mathematics answer. There is no such concept as a ratio of differentials. What you have is a derivative, defined in the usual way, and it is the cross section as a function of direction.
Physics contribution. The numbers that are used for the cross sections are obtained by experiments as described.
