Thread Closed
Parallel Plate Capacitor and distance
Share Thread Thread Tools
Mar29-06, 01:54 PM   #1
Red face
I'm going through my book and one of the Example exercises has the following problem:
Two plates, each of area 3X10^-4 m^2 are used to construc a parallel-plate capacitor with capacitance 1 pF. (a) Find the necessary seperation distance.
Seems pretty obvious right? C = Eo(A/d)
So, I figure I'm finding d = C/(Eo)(A)
but it doesn't come out right, so I must be missing something either in my math (not surprising) or the area. Do I need to do a calculation with the area? Like 2 X A? That doesn't work either, and it doesn't seem right to do it that way. Help, please??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar29-06, 02:08 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Its just your manipulation which is letting you down. It should be;
[tex]C = \frac{E_{0}A}{d}[/tex]
[tex]C \cdot d = E_{0}\cdot {A}[/tex]
[tex]d = \frac{E_{0}A}{C}[/tex]
-Hoot
Mar29-06, 02:12 PM   #3
Quote by Hootenanny
You are awesome!! Thank you!!
Mar29-06, 02:39 PM   #4
Recognitions:
Homework Helper Homework Help
If you are assume the dielectric is air (k ~ 1) and [itex] \epsilon_o = 8.854 x 10^{-12}[/itex] F/m, you may get d = 2.656 mm. A more general formula for this type question may be found here.
In agreement with Hoot, i noticed the same fault in rearranging your equation. It is a good idea to do a couple of things to double check maths. One is to do the algebra step by step, the other is to do a quick dimensional analysis of the final equation. In your case, you have A left in the denominator. The only way that would work and have answer come out in meters is to have [itex]m^3[/itex] in the numerator, which you don't have.
Mar29-06, 03:08 PM   #5
Wow. Thank you, that is most helpful. The link is terrific. Again, thank you!
Thread Closed
Thread Tools
Similar Threads for: Parallel Plate Capacitor and distance
Thread Forum Replies
Non-parallel Plate Capacitor Introductory Physics Homework 2
parallel plate capacitor (voltage and charge relative to distance) General Physics 2
A proton is released from rest at the positive plate of a parallel-plate capacitor. Introductory Physics Homework 16
Parallel Plate Capacitor Introductory Physics Homework 1
The parallel-plate capacitor Introductory Physics Homework 3
