How Can I Efficiently Read Multiple Resistor Values for Temperature Mapping?
  • Thread starter Thread starter rsnd
    Computer
The discussion revolves around the challenge of efficiently reading multiple resistor values from varistors used for temperature mapping in a room. Participants explore various methods for interfacing with these sensors, including hardware solutions and programming considerations.
  • Experimental/applied
  • One participant describes having 14 varistors that produce specific resistances based on temperature, and seeks a method to read these values efficiently.
  • Another suggests using a data acquisition (DAQ) board to handle multiple voltage inputs or switching groups of four varistors to read them sequentially.
  • A different viewpoint proposes purchasing additional joystick port cards to increase the number of inputs available.
  • Concerns are raised about reading multiple values simultaneously, as one participant notes that reading four varistors at once can lead to inaccurate readings.
  • One participant proposes using a demultiplexer controlled by a parallel port to select which varistor to read, while expressing concerns about the size and aesthetics of relays.
  • Another suggests using solid state relays as a smaller alternative and mentions the possibility of using external ADC cards or building a custom solution with microcontrollers.
  • It is noted that varistors may not be the most reliable temperature sensors due to issues like self-heating and noise, with a recommendation for solid state temperature sensors like the LM335Z.
  • Participants discuss the feasibility of using a printer port for digital I/O to control multiplexers or ADCs, with cost estimates provided for potential solutions.
Participants express a range of opinions on the best approach to reading the resistor values, with no consensus on a single solution. Some advocate for using multiplexers and ADCs, while others question the reliability of varistors as temperature sensors.
Participants mention various hardware limitations, such as the number of available ports and the potential for inaccuracies in readings due to the nature of varistors. There are also unresolved considerations regarding the best methods for interfacing with the sensors and the implications of using different types of components.
rsnd
well...I have 14 varisters equally distributed on the walls of my room(FCC Structure) which will produce specific resistances depending on the temperature on that place. And my program is to read those resistance values and convert them into temperatures. Then it is to apply larplace's transformation to generate a graph of the temperature distribution of my room.
My problem is...How do I get my program to to read 12 resistor values! I can use the joystick port to read in 4!
You're going to need some kind of DAQ board that will accept that many voltage inputs. You could possibly work out a way to switch in groups of four and capture 4 at a time. That's basically how data buckets work by scanning each channel over a specified interval.
If you can do it with a joystick port, can't you just buy some more joystick port cards?
Well, Ideally I should be reading 1 value at a time because 4 varisters at once tends to increase the values read inside.
Anyways... Is it possible doing it through a demultiplexer...if I have the input as +5v or something and then use parallel port output bits to set a perticular channel voltage to high which will trigger a relay which will allow me to read those analog values. But then tehre are other problems :( like...relays are big and ugly and don't look good on circuit boards :( Ill try to look for smaller relays to see if i have any luck.
And don't have that many free slots to put in joystick ports. I think they only come with sound cards now a days.
You could use solid state relays, much smaller and would work since each line in the parallel port can only source maybe 10mA but I think can sink 30mA, don't remember what the +5 can source but you could always tap that elsewhere.
You can purchase external ADC cards with many inputs, or build your own with a PIC or two that can already mux the ADC across a few inputs already. I've seen some nice looking (no experience with) ADC cards now with USB ports that emulate serial ports. Pretty easy to write a few lines of code to work with that and that's pretty awesome portability.
a joystick will only have 2 pots (for a start).
varistors are "slow" sensors, and you can scale their value to the expected limits of your measurement. 14 varistors, might as well make it 16 sensors.
if your joystick card can read 2 pots, you will need some kind of multiplexer, (quad bi-lateral switch), like a 4016.
the other option is to purchase 2 8channel 8 or 10 bit ADC's (analog to digital converters), these are VERY CHEAP, and spit out their readings of your sensors, in a nicely computer readable form.
your Printer port, can be easily used for simple digital I/O, and you can use that port to switch through the channels of your ADC's and record the values you are after.
or you can use your printer port to control your multiplexer switch, (4 lines required for 1 of 16 selection), and use 1 of your joystick pot inputs and the measurement input, and the second joystick pot input as a reference.
i would estimate the total cost of your measurement system (except varistors). to be mabey $30 or so. depending on your willingness for comprimise.
i hope that help.
there are many (and more expensive methods), plug in DAC/ADC cards are a great option.
(i use C and LabVIEW, for my software development for instrumentation)
or you can purchase a Microprocessor development board, like something from ATMEL, they have 8 channel ADC's onbaord, (10-bit), can operate stand along, and communicate via RS-232 to your PC. (plus they are great fun to play with !).
varistors are not that great as reliable temperature sensors, they have problems with self heating, if you apply too much excitation, and long wire runes will introdue errors. not enough will introduce noice and uncertainty.
have a look at solid state temperature sensor, more accurate and easy to scale and interface.
like the LM335Z.
you will require 4 digitial outputs to switch 16 signals to one channel.
or 2 times 8 channel 10-bit ADC's that you can read from your Printer port. (printer port = cheap digital I/O).
your problem may due unnecssory progr mas
  • · Replies 23 ·
  • · Replies 37 ·
10K
