Deriving Wien's Law from Planck's Formula
  • Context: Graduate
  • Thread starter Thread starter Dorje
    deriving Formula Law
The discussion focuses on deriving Wien's displacement law, represented as λmaxT = 2.898 x 10^-3 mK, from Planck's formula for blackbody radiation. The user attempts to differentiate the formula and set dR/dλ = 0, leading to a complex transcendental equation. The presence of the term "5kTλ" raises questions about the derivation's validity. The response indicates that exact solutions for such transcendental equations are generally unattainable, suggesting a deeper exploration of the Wien approximation.
  • Understanding of Planck's formula for blackbody radiation
  • Familiarity with Wien's displacement law
  • Knowledge of differentiation techniques in calculus
  • Concept of transcendental equations in mathematics
  • Study the derivation of Wien's law from Planck's formula in detail
  • Learn about transcendental equations and their properties
  • Explore the Wien approximation and its applications in physics
  • Investigate numerical methods for solving transcendental equations
Physicists, students of modern physics, and anyone interested in the mathematical foundations of thermodynamics and blackbody radiation.
Dorje
As a refresher exercise in modern physics, I want to derive Wien's displacement law:
[tex]\lambda_{max}T=2.898x10^{-3}mK[/tex]
from Planck's formula:
[tex]R(\lambda)=(\frac{c}{4})(\frac{8\pi}{\lambda^4})(\frac{hc}{\lambda})(\frac{1}{\exp^(\frac{hc}{\lambda\kT})-1})[/tex]
by differentiating R([tex]\lambda[/tex]) and setting dR/d[tex]\lambda[/tex] = 0. I get to an expression like this:
[tex]\exp^(\frac{hc}{\lambda\kT})(hc - 5kT\lambda)+5kT\lambda=0[/tex]
If it wasn't for the "5kT[tex]\lambda[/tex]" term by itself on the left-hand side of the equation, the solution would simply be:
([tex]\lambda[/tex]) (T) = hc / 5k
which is Wien's law. There must be something wrong though, or maybe there's a trick involved that I'm not seeing?
Thanks
Yes, you're dealing with a typical transcendental equation, to which exact solutions cannot be found in most cases, this one included.
Daniel.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 18 ·
15K
