Possible webpage title: What are the Known Patterns in Prime Numbers?
The discussion revolves around the known patterns in prime numbers, focusing on explicit formulas and relationships between primes. Participants explore theoretical aspects, mathematical reasoning, and the nature of patterns in sequences, particularly in relation to prime numbers.
  • Some participants inquire about explicit formulas that describe relationships between prime numbers.
  • The Prime Number Theorem is mentioned, indicating that the density of primes decreases as numbers increase, with specific probabilities given for large values of N.
  • One participant notes that all prime numbers have exactly two distinct divisors.
  • Another participant asserts that while a pattern exists among primes, it remains unknown.
  • There is a discussion about the definition of "pattern," with some suggesting it refers to formulas and others arguing it relates to observable occurrences in real life.
  • A participant references an algorithm that can generate prime numbers, discussing the implications of such algorithms on the existence of patterns.
  • Wilson's theorem is introduced as a potential method for identifying primes through a specific formula involving factorials.
  • There are disagreements regarding the nature of patterns, with some asserting that not all sequences necessarily exhibit simple patterns, particularly in the case of primes.
Participants express differing views on the existence and nature of patterns in prime numbers. While some agree that patterns exist, there is no consensus on what constitutes a pattern or how it can be defined mathematically. The discussion remains unresolved regarding the implications of algorithms and the nature of sequences.
Limitations in definitions of "pattern" and the implications of algorithms on the understanding of prime sequences are noted, but remain unresolved. The discussion highlights the complexity of relating mathematical functions to sequences of primes.
roger
Hi,
I just wondered what patterns are known about the prime numbers ?
cheers
roger
Mathematics news on Phys.org
by pattern I mean any explicit formulas which give certain relations between primes.
The Prime Number Theorem states that if you randomly select a number nearby some large number N, the chance of it being prime is about 1 / ln(N), where ln(N) denotes the natural logarithm of N. For example, near N = 10,000, about one in nine numbers is prime, whereas near N = 1,000,000,000, only one in every 21 numbers is prime.
In other words, the prime numbers "thin out" as one looks at larger and larger numbers, and the prime number theorem gives a precise description of exactly how much they thin out.
Well, one pattern I've noticed is they all have exactly 2 distinct divisors :shy:
There is a pattern. We just don't know what it is yet.
Then what do you mean by "pattern"?
We know exactly when primes occur, and we have efficient methods for telling if a given number is a prime. We even have explicit formulas for the n-th prime number.
By pattern, I mean formula.
Where is this explicit formula?
How do we know there is one?
f(x) = px where pi is the ith prime.
Patterns are more to do with spotting simple occurrences in real life, not much to do with mathematics.
I don't agree with that statement.
It was proven that if an algorithm can be made so that a computer can spit out the sequence, then a formula exists. Hence, a pattern.
That might not be very meaningful regarding the sequence of primes. For every algorithm there is an equivalent series of mathematical operations, or, if you combine these statements, a mathematical function. Hence, if an algorithm can "spit out" all the primes, then there is a mathematical function that produces that sequence. However this mathematical function can very well be infinite. This is the case with the sequence of primes. There is a very simple algorithm that outputs all the primes. Namely one that iterates through all the positive integers and divides each number by those that come before it (and are bigger than one), outputting a number when it is not divisable.
In order to output the sequence of all the primes this algorithm would need infinite time, an infinite sequence of operations and thus be equivalent to an infinite mathematical function.
What pattern exists there then?
If instead we wanted to output the first 100 primes, than the above algorithm would take less than 1000 operations, the equivalent mathematical function have in the order of 1000 operations. Would the sequence have a pattern?
For every sequence there is an algorithm that outputs all the elements in that sequence, it may require infinite memory and infinite time, but it will output all the elements in that sequence, does every sequence have a pattern then?
My definition of a pattern is something that is repeated. Yet, for every sequence of numbers without repetition, such as the primes, the digits of pi, etc, there is an algorithm capable of outputting that sequence.
I would say, if an algorithm can output any n elements of a sequence in O(n) time, with finite memory, then the sequence has a simple pattern. If it requires more then i don't know, but it certainly isn't a simple pattern.
From..Wilson,s?..theorem we could find a formula to obtain primesifwe define:
[tex]g(x)=[\frac{(x-1)!+1}{x}]-\frac{(x-1)!+1}{x}[/tex]
where for the factorial we know the recurrence [tex](x+1)!=xx![/tex]
then every time g(x)=0 for an integer x we know that this x is prime...where [] is the "floor" function which is always an integer...
Well define what a pattern is in mathematics for me then.
Lots of mathematical functions can be described as being 'infinitely long' take for example all taylor series, this does not make them less useful/
That's a particularly inefficient way but o.k.
That makes no sense, it takes an infinite amount of time to output all natural numbers i.e {1, 2, 3..) on a computer, would you describe the mathematical function f(x) = x as being infinite?
Most of that is so much gibberish I can't really make sense of. Algorithms exist that calculate if a number is a prime or not, much faster than O(n).
I never said simple pattern.
Also, even if you give a computer the direct formula of a sequence, it requires more and more memory as n gets larger. So, your point is invalid.
Okay.
It's odd you would think that the sequence 1, 2, 3, 4, 5, 6, ... of positive integers, in order, doesn't have a simple pattern!
The list consisting of the first N integers has length [itex]\Omega (N \lg N)[/itex], so any algorithm for computing this sequence must take [itex]\Omega(N \lg N)[/itex] time.
If you don't allow the algorithm to review what it's already printed, it must require [itex]\Omega(\lg N)[/itex] memory to output the first N terms of this sequence. If you do allow the algorithm to review what it's already printed, I suspect it still takes [itex]\Omega(\lg \lg N)[/itex] memory, but I haven't worked out a proof yet.
That's not true! There are countably many algorithms, and uncountably many sequences. (Even if we only consisder sequences whose terms are either 0 or 1)
You're misinterpreting me. I said if the algorithm takes a finite amount of memory, meaning if the algorithm can be stored in a finite amount of memory, meaning that if you had an algorithm you'd be able to store it in a hard drive with finite capacity, meaning that the algorithm isn't infinitely large. I didn't mean memory usage at run time. For that i would bound it at about O(n).
Hurkyl said:
Okay.
My definition, where i mentioned O(n) wasn't with respect to the number of bits (that was patent in my statement, i thought). So a list composed of the first n integers would require O(n).
But an algorithm doesn't have to create a sequence. The sequence might be embedded in the algorithm, hence to print a sequence all we have to do is:
mySequence = [2, 3, 5, 7, 11, 13, 17, 19 ...];
while(true){
trace("f(" + i + ") = " + mySequence);
For an infinite sequence the algorithm is infinitely large (requires infinite memory) and takes infinite time (has to of course). However, for every sequence, there is an algorithm that prints all the elements in that sequence. Unless we choose to define algorithms as something finite. Do you see what i mean?
To reiterate more precisely:
If an algorithm of finite size can output the first N elements of a sequence in O(N) time with O(N) memory, or, in other words, in O(2^n) time and O(2^n) memory where n=log(N), then that sequence has a simple pattern.
This was an impulsive statement, so if it isn't very adequate I'm not going to cry over it. :smile:
As you haven't defined 'simple' your statement is vacuous or tautological.
Let's make it the definition of "simple pattern" then, and work with that. :)
Then it is tautological, so who can argue against it, but also a meaningless statement at the same time.
Yes, or, you could argue that the definition of a simple pattern ought to encompass more, or less, than the definition above. Maybe argue why certain patterns should be classified as simple when the current definition doesn't classify them as such (like Hurkyl, when he proposed 1, 2, 3, 4...). A sort of a progressive discussion. I think it's acceptable.
  • · Replies 23 ·
  • · Replies 58 ·
10K
