Regarding the discovery of quantum theory
The discussion centers on Max Planck's introduction of quantum theory to resolve fundamental issues in classical physics, particularly regarding black body radiation. Classical theories, such as Galileo's planetary motion and Newton's gravity, failed to explain the thermal equilibrium of the electromagnetic field with matter, leading to nonsensical predictions of infinite energy. Planck's hypothesis that electromagnetic modes exchange energy in discrete packets, or "quanta," allowed for a coherent energy distribution that matched empirical observations of black body radiation. This marked a pivotal shift in understanding thermal dynamics and energy distribution in physics.
  • Understanding of classical physics principles, including thermal equilibrium and equipartition theorem.
  • Familiarity with electromagnetic theory and black body radiation concepts.
  • Knowledge of statistical mechanics and Boltzmann's constant.
  • Basic grasp of quantum mechanics and Planck's constant.
  • Research the derivation of Planck's law of black body radiation.
  • Study the implications of quantum mechanics on thermal dynamics.
  • Explore the equipartition theorem and its limitations in infinite systems.
  • Investigate the historical context and development of quantum theory post-Planck.
Physicists, students of quantum mechanics, and anyone interested in the historical evolution of scientific theories related to energy and thermal dynamics.
shaan_aragorn
Why did Max Planck think that energy ought to be radiated in quantas? What were the shortcomings of the earlier theories that made the Quantum Theory a necessity. For example, the shortcomings in Galileo's model of planetary motion was that it could not explain why did the planets revolve around the sun. Newton took care of that with his theory of gravity. My question rests on the same lines, what were the disadvantages of the theories before the quantum theory?
If light were not radiated in quantas, then black body radiation should be infinite, since it is across all frequencies at once.
As Russ already pointed out, the problem to be solved was a rather "fundamental" one concerning black body radiation. In fact it was not "just" conflict with experiment, it was a *fundamental* difficulty in classical theory.
The problem was: what's the THERMAL EQUILIBRIUM of the electromagnetic field with matter. Now, it was VERY WELL established that thermal equilibrium in classical physics occurred when EACH DEGREE OF FREEDOM of the system had an average energy of 1/2 k T, with k Boltzmann's constant, and T the absolute temperature. This is called the "equipartition rule". It finds its origin in the fact that if you distribute energy that way, you arrive at the largest number of "equivalent" microstates - which is exactly what equilibrium is supposed to mean. Now, as long as a system has a FINITE number of degrees of freedom, there's no problem: you take your energy budget, divide it over that number of degrees of freedom, and you have your temperature. OR, you have your temperature, give each degree of freedom its energy 1/2 kT, and summing, you find your total energy.
But you run in a serious difficulty if you consider an INFINITE number of degrees of freedom, such as is the case with the EM field. Even in a cavity, there's an infinite number of EM modes, because frequency is not limited upwards. So if you use this equipartition rule for EM, you end up with: 1) infinite energy in the EM field, and 2) most energy in the high frequency modes (of which there are many). In other words, from the moment you have non-zero temperature, you would have something like a strong X-ray and gamma ray source.
This was of course not only experimentally not observed, but was even nonsensical from the purely theoretical PoV, because it would mean that any system with a finite amount of energy, coupled to an EM field, would end up at T = 0 K (ALL of its energy would be sucked up by the EM field in its way to establish thermal equilibrium).
This was the fundamental difficulty classical physics faced and which was solved by Planck's totally ad hoc hypothesis of saying that EM modes could only exchange energy with matter in "lumps" of hv.
By just making this hypothesis, and applying some statistical reasoning to it, Planck could show that he found an energy distribution curve for an EM field in thermal equilibrium which corresponded to the empirically observed "black body" radiation curve".
  • · Replies 58 ·
  • · Replies 120 ·
14K
  • · Replies 21 ·
