| Thread Closed |
calculating drag |
Share Thread | Thread Tools |
| Apr11-06, 05:19 AM | #1 |
calculating drag
i am having trouble calculating various drag co-efficents for a dc -10 in cruise.
i have found this data: Thrust: 153000 lb density: 0.00085 slug/ft V= 852ft/s W=580000lb AR= 7.5 e= .8 S= 3958ft^2 Cl= 0.5 I have also found the formulas Cd= D/ (density x S x V^2 /2) Cd= Cdo + ((cl^2) / (pi x AR x e)) Cdi= (cl^2)/ (pi x AR x e) i have tried these but get odd answers. i need help to know whether my mistake is my data, my formulas or my calculation. help with graphing this data vs airspeed would also be appriciated cheers |
| Apr11-06, 06:40 AM | #2 |
Recognitions:
It appears that you have all the information you need to do the calcs. Perhaps it is a units issue? If you show us what you have we might be able to pinpoint something for you.
| Apr11-06, 12:29 PM | #3 |
Is that value for S right?
It looks rather large indeed, but then I'm too snobby to work in imperial units to find out for sure. |
| Apr12-06, 04:16 AM | #4 |
calculating drag
the answers that i got using these formulas were:
for Cd = 0.125 for Cdi= 0.0137 for CDo = 0.11 as cdi and cdo were so different i thought that there must be a problem. i was also unsure if the thrust value given was for one engine or for all three. is it an appropriate value for three engines? -in response to brewnog S= 317 m ^2 |
| Apr12-06, 06:42 AM | #5 |
Recognitions:
The thrust value you give is consistent with three engines. 50,000 Lbf sounds about right for a single engine.
Did you do a dimensional analysis to make sure your units were all cancelled out? |
| Apr17-06, 07:37 PM | #6 |
i did a dimensional analysis. but i'm pretty sure that i'm using all the right units. still having problems though. are the formulas correct and is the oswald efficency factor an approptriate value for a DC - 10?
| Thread Closed |
| Thread Tools | |
Similar Threads for: calculating drag
| Calculating air drag | Introductory Physics Homework | 1 | ||
| Help with Drag. | Introductory Physics Homework | 3 | ||
| Calculating viscous drag in water | Mechanical Engineering | 2 | ||
| Calculating air drag for a massive rocket | General Physics | 6 | ||
| Calculating drag | Classical Physics | 3 | ||
