Can Unequally Spaced Blades Reduce Noise in Radiator Fans?
  • Thread starter Thread starter Hootenanny
    Rain Work
The discussion revolves around the mechanics of tire treads in wet conditions and the potential benefits of using unequally spaced blades in radiator fans to reduce noise. Participants explore the relationship between tread design and water displacement, as well as the implications of blade spacing on fan performance and noise reduction.
  • Some participants explain that tire tread patterns are designed to channel water away to maintain traction and reduce aquaplaning, highlighting the importance of tread design in wet conditions.
  • Others discuss the trade-offs in tire design, noting that optimizing for wet performance may compromise tread life.
  • Participants mention that regularly spaced grooves in tire treads can create harmonics leading to vibrations, suggesting a reason for the complexity of tread designs.
  • One participant introduces the idea of experimenting with radiator fans that have unequally spaced blades, proposing that this design could significantly reduce noise if balancing issues are addressed.
  • Another participant reflects on the connection between harmonics in tires and fans, indicating a broader application of these principles.
  • There is speculation about the design of fan blades, with a suggestion that blade profiles may vary in addition to spacing.
Participants generally agree on the importance of tread design for tire performance in wet conditions, but there is no consensus on the implications of unequally spaced blades in radiator fans, as this remains an area of ongoing experimentation and discussion.
Participants acknowledge various factors influencing tire performance, including tread wear and the balance between aesthetics and functionality. The discussion on radiator fans is still in the experimental phase, with uncertainties regarding balancing and performance outcomes.
This discussion may be of interest to those studying automotive engineering, mechanical design, or acoustics, as well as individuals curious about the interplay between design and performance in engineering applications.
Hootenanny
Staff Emeritus
I was just curious to how tyres work in the rain. How does the tread shift the standing water so the tyre can have traction? Any information would be appreciated.
The varied geometric shapes of a tires tread serves to deflect the water into raised "channels" between these geometric shapes.
The challenge is that these shapes must have sufficient surface area, else they would wear down quickly.
So, there is a trade-off. Yes, you could design a tire that is extremely optimal in rain, but in so doing, it might have very poor tread life.
I suppose they strike a happy medium.
The first most significant feature is a tread. You can have the stickiest compound in the world, but if you have no tread, wet weather performance will be rubbish. As you know, tread patterns break up the layer between the rubber and the tarmac so that aquaplaning is discouraged.
As a tyre rolls over wet tarmac, a 'wedge' of water forms in front of the tyre. If the tyre rises up on this wedge, contact between the tarmac and rubber is broken, and aquaplaning occurs. By breaking up the surface of the tyre such that there are channels for this water wedge to infiltrate, the tyre is less prone to rising up on the wedge. For a similar reason, (like-for-like) narrow tyres perform better in very wet conditions, - the tyre is less prone to 'floating' up onto the wedge of water.
More detail: Circumferential grooves (going 'around' the tyre) act as channels to drain the wedge, and to some extent, store this water. Lateral grooves, - going side-to-side across the width of the tyre - drain this water from the circumferential 'grooves' to the tyre edges. At 100km/h, an average tyre in average rain needs to shift something like 6 litres of water per second to maintain contact. New wet tyres have massive grooves in the centres which can displace huge amounts of water, - something like 10 litres per second, but these wear very quickly in the dry. Circumferential 'ribs' provide contact zones, particularly for cornering. Small, shallow dimples around the shoulders of the tyre increase surface area to allow for more efficient cooling. Sometimes a 'void ratio' is specified, which quantifies the amount of non contact/ contact area across the width of the tyre, - for a slick tyre this ratio will be 0%, for an off-road mud or snow tyre this will be much higher, perhaps 40%?
More detail still: Tread patterns vary for a number of reasons. Simple block-shaped treads fundamentally work well in muddy and wet conditions, but are prone to rapid wear of the front and back of the block on dry tarmac. Regularly spaced grooves are avoided because they set up harmonics which can cause hefty vibrations.
Finally, asymmetrical tyres will have more large blocks on the outside for cornering stability, and smaller blocks on the inside for heat dissipation and water displacement.
Thank-you both of you. That was excellent. :biggrin:
Sunufagun. Lots of interesting info there, more than I ever knew about tires, but surely, this is by far the most interesting bit:
"...Regularly spaced grooves are avoided because they set up harmonics which can cause hefty vibrations..."
which explains one of the most curious aspects of tire treads - the complexity of the geometrical shapes.
It's not the only explanation. Looks are a major selling point, and it's quite a hard job to design a tyre which performs well, and also looks the part.
Interestingly, we're currently experimenting with radiator fans with unequally spaced blades, - it's looking like noise can be drastically reduced if we can address the balancing.
Well, good look with that. I've never thought about harmonics with tyres, fans and such like before. Puts a different perspective on things :smile:
Hmmm... I saw a car fan once that had five blades, not equally spaced. Maybe that's what it was all about.
Balancing and performance I would also imagine. I would tend to think that the blade profiles would not be the same. Interesting...
  • · Replies 18 ·
21K
9K
11K
  • · Replies 19 ·
