Thread Closed
LCAO Basis Sets
Share Thread Thread Tools
Apr12-06, 11:21 AM   #1
LCAO Basis Sets
Hello,
Haven't been here in a while. Does the Linear Combination of Atomic Orbitals (LCAO) method of developing a basis set imply tight-binding ? Is there a way of using this basis set for not so tigtly bound (there is appreciable overlap) atomic orbitals and still maintain orthagonality between the atomic orbitals, which is required for a basis set representing the lattice wavefuntion ? I'm leaning towards no, but maybe somebody else has other information.
Best Regards
Modey3
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
Apr12-06, 04:58 PM   #2
I'd lean to no aswell. If you have appreciative overlap you can't really use perturbation theory to get the eigenstates. A couple of texts I checked also assumed that there's no overlap at all.
May2-06, 08:30 AM   #3
Quote by Modey3
Modey3
One can even use the LCAO approach to study metals like Ta. I am currently doing such DFT simulations where i use a DZP basis set to describe the electronic wavefunctions. Keep in mind that these orbitals are NOT really the QM atomic orbitals. They contain parametrisations that arise from the DFT formalism. Check the Vanderbilt website for more info.
marlon
May2-06, 11:06 AM   #4
LCAO Basis Sets
Thanks Marlon,
DZP basis sets are new to me (I just started learning about Ab Initio modeling). Are they only used to provide the basis sets for DFT , or can they be applied to tight-binding schemes even though they arn't atomic orbitals.
This is a little off topic. When studying quantum dots that have limited periodicity. Is it true that the wave function of an electron will not have the form dictated by Blochs Theorem? When one does tight binding calculations for quantum dots do we throw out the requirement that the LCAOs for each orbital (s,p etc..) obey Blochs Theorem? I'm still trying to learn the subtle difference in doing bulk and nanostructure calculations.
Regards
Modey3
May8-06, 09:20 AM   #5
Quote by Modey3
Thanks Marlon,
Yes ofcourse. These basis sets contain parameters that you can change. By changing them you acquire wavefunctions that resemble the atomic orbitals at hand while keeping the computational effort "low".
Regards
Modey3
The Bloch Theorem is valid due to the atomic/crystal structure of the material at hand. Even if the material is very small, Blochwaves can still be used as long as there is certain crystal symmetry.
For example, Bloch waves are used in interface simulations of a metal gate and a high k material. The magnitude of such a system is in the nanometer range (ie the thickness). Keep in mind that with DFT, one can only simulate input cells containing 200 atoms at maximum !!!
regards
marlon
Thread Closed
Thread Tools
Similar Threads for: LCAO Basis Sets
Thread Forum Replies
matrix connecting Sz diagonal basis to Sx diag basis Quantum Physics 0
Lcao Theory Atomic, Solid State, Comp. Physics 0
finding sets, listing sets (discrete math) Calculus & Beyond Homework 2
Determining if the following sets span R^3 and creating a basis, wee! matrices Calculus & Beyond Homework 1
sources for LCAO theory? Quantum Physics 3
