Pleasez check the answers to these difficult questions?
  • Thread starter Thread starter sapta
The forum discussion centers on mathematical questions regarding inequalities, prime numbers, and properties of complex numbers. The user presents four questions, concluding that for the first question, option d is correct based on specific values of a and n. For the second question, it is established that 1 is not a prime number. The third question's answer is debated, with the user suggesting option b, while the fourth question's correct option is identified as a, though clarification on a specific step is requested.
  • Understanding of real numbers and their properties
  • Familiarity with prime number definitions and characteristics
  • Knowledge of complex numbers and their modulus
  • Basic algebraic manipulation and inequalities
  • Study the properties of inequalities in mathematical analysis
  • Explore the definitions and characteristics of prime numbers
  • Learn about complex number operations and their geometric interpretations
  • Review algebraic proofs involving sequences and series
Mathematics students, educators, and anyone interested in advanced mathematical concepts, particularly in number theory and complex analysis.
sapta
A book of mine has the following questions with no answers.So I am not sure if I am right or if the proceure is correct and the best.So,please help-
1.For a given real number a>0,define[tex]A_n=(1^a + 2^a + 3^a +...+n^a)^n[/tex]
and[tex]B_n=n^n(n!)^a[/tex] for all n=1,2,... Then
a. [tex]A_n<B_n[/tex]for all n>1
b.there exists an integer n>1 such that [tex]A_n<B_n[/tex]
c.[tex]A_n>B_n[/tex] for all n>1
d.there exists integers n and m both larger than one such that [tex]A_n>B_n[/tex] and [tex]A_m<B_m[/tex]
As there's no specification about the value of a in the options given,I considered a special case taking a=1 and then put n=2 and n=3.I found [tex]A_n>B_n[/tex] and [tex]A_n<B_n[/tex] respectively.So I think the answer is d.
2.Is 1 a prime number?
3.Let C denote the set of all complex numbers.Define A and B by
A={(z,w):z,w [tex]\in[/tex]C and mod z=mod w}
B={(z,w):z,w [tex]\in[/tex]C and [tex]z^2=w^2[/tex]}
Then
a.A=B b.A[tex]\sqsubseteq[/tex]B and A not equal to B
c.B[tex]\sqsubseteq[/tex]A and B not equal to A
d.none of the above.
I think z^2=w^2 means mod z=mod w but the reverse is not true,so is the answer b?
4.If positive numbers a,b,c,d are such that 1/a,1/b,1/c,1/d are in A.P then we always have
a.a+d[tex]\geq[/tex]b+c b.a+b[tex]\geq[/tex]c+d
c.a+c[tex]\geq[/tex]b+d d.none of the above
1/a +1/d =1/b +1/c or,(a+d)/ad =(b+c)/bc. Now 1/ad<1/bc or,ad>bc.so,a+d[tex]\geq[/tex]b+c i.e.,(a)?
thanking you in advance.And how do you put "not equal to" and "modulus" in latex?
Reply
Hi! Here are some of my thoughts with regard to your questions...
Q2) 1 is not a prime number. A prime number is defined as a number which is divisible only by itself and one. It can then be taken to mean that every prime number has 2 distinct factors. Hence, 1 is not prime.
Q3) Your reasoning that "[tex]z^2=w^2[/tex] means [tex]\mid z \mid =\ \mid w \mid[/tex] but the reverse is not true" is valid. However, doesn't this mean that all elements in B are in A but not all elements in A are in B? So, the answer is...
Q4) (a) is indeed the correct option, but I do not understand one of the steps in your working. Why do you immediately conclude that [tex]\frac{1}{ad} < \frac{1}{bc}[/tex]? Can you clarify? Thanks.
