Probability of transition in hydrogen atom
The discussion focuses on calculating the first-order probability of a hydrogen atom transitioning to the 210 (nlm) state when subjected to an external electric field E(t)=E*exp(-t/tau). The approach involves using time-dependent perturbation theory to find the average perturbation and the amplitude c_{f i} for the transition. The spontaneous transition probability for the 2p -> 1s transition is considered negligible, guiding the analysis towards the electric dipole approximation for absorption and stimulation effects.
  • Time-dependent perturbation theory
  • Matrix elements in quantum mechanics
  • Hydrogen atom wave functions
  • Electric dipole approximation
  • Study the derivation of time-dependent perturbation theory
  • Learn about matrix elements and their calculation in quantum mechanics
  • Explore the electric dipole approximation in detail
  • Investigate the specific wave functions for hydrogen atom states
Quantum mechanics students, physicists working on atomic transitions, and researchers interested in perturbation theory applications.
mathlete
Here's the question...
A hydrogen atom is in the ground state at time t = 0. At this time an external electric field of magnitude E(t)=E*exp(-t/tau) is applied along the z direction. Find the first-order probability that the atom will be in the 210 (nlm) state at time t >> tau, assuming that the spontaneous transition probability for the 2p -> 1s transition is negligible at that time.
What I'm thinking is I need to find the average pertubation (<psi|H'|psi>) and then use time dependent pertubation theory to solve this... but I'm not really sure what wave functions i'd use to do this. But also I'm conflicted if I should really be doing it this way and not using something for absorption/stimulation in the electric dipole approximation... any suggestions?
Hi mathlete,
This is straight time dependent perturbation theory. You need to calculate the amplitude [tex]c_{f i}[/tex] to go from the initial state i to the final state f. Your book will certainly contain the relevant formulae, but basically you know that the amplitude is proportional to the matrix element of the perturbation between the initial and final states with some integral that captures the time depedence.
Hope this helps.
  • · Replies 0 ·
