Can Worm Gear Work w/ Spur Gear for Model?
  • Thread starter Thread starter shwagy357
    Gear
Using a worm gear mechanism with a spur gear is feasible, particularly for small models made from acetal plastic. The critical factor is ensuring that the pitch of the lead screw is equal to or slightly larger than that of the spur gear. However, this combination results in reduced gear life and increased mechanical losses due to friction and impact loading, making it less efficient than a properly matched gear set.
  • Understanding of gear mechanics, specifically worm and spur gear interactions
  • Knowledge of material properties, particularly acetal plastic
  • Familiarity with gear pitch and its implications on performance
  • Basic principles of mechanical efficiency and friction in gear systems
  • Research the design principles of worm gear mechanisms
  • Explore the properties and applications of acetal plastic in mechanical models
  • Learn about gear pitch calculations and their impact on gear compatibility
  • Investigate methods to reduce friction and improve efficiency in gear systems
Model makers, mechanical engineers, and hobbyists interested in gear design and optimization for small-scale projects.
shwagy357
Does anyone know if it is possible to get a worm gear mechanism to work using a spur gear. I am just trying to make a small model of a worm gear out of acetal plastic for demonstration purposes only. I am thinking it might work as long as the pitch on the lead screw, is the same or a little larger than the pitch on the spur gear. What do you guys think?
You can do it, but it's not pretty. I've had to use a system like that in an emergency a couple of times. Your gear life is pretty short compared to a properly matched set, and there's a lot more mechanical loss due to friction, impact loading, etc..
  • · Replies 23 ·
