How Do You Calculate Chemical Reaction Yields?
  • Thread starter Thread starter skyblueff0
    Chemistry Homework
The discussion revolves around calculating chemical reaction yields through stoichiometry, focusing on specific homework problems involving various chemical reactions. Participants explore methods for determining masses of reactants and products based on given equations.
  • Homework-related
  • One participant requests help with four specific stoichiometry problems related to chemical reactions and yields.
  • Another participant suggests calculating molecular weights and moles to find the mass of lithium hydroxide produced from lithium nitride reacting with water.
  • For the decomposition of hydrogen peroxide to produce water, a participant advises determining the reaction and applying similar stoichiometric calculations.
  • A suggestion is made to track reaction ratios when calculating the mass of benzene needed to produce carbon dioxide gas at STP.
  • Participants mention the importance of balancing chemical equations and provide tips for converting between grams, moles, and liters.
  • One participant shares a mnemonic for remembering the conversions between grams, moles, and liters.
Participants generally agree on the approach to solving stoichiometry problems, but there is no consensus on specific solutions to the homework problems presented.
Participants emphasize the need to balance chemical equations and the importance of molecular weights in calculations, but specific details on the reactions and conversions remain unresolved.
skyblueff0
okay I am going to give you like 4 problems out of like 22 i need to do for homework before the breaks is over can someone just tell me what formula to use, or it would be even better if someone can show me
" "- subscript numbers
1. Determine the mass of lithium hydroxide produced when 0.38g of lithium nitride reacts with water according to the following equation: Li"3"N + 3H"2"O --> NH"3" + 3LiOH
2.What mass of hydrogen peroxide (H"2"O"2") must decompose to produce 0.77g of water?
3.Find the mass of benzene (C(6)H(6)) required to produce 2.66 L of carbon dioxide gas at STP from the reaction described by the following equation : 2C"6"H"6" + 15O"2" --> 6H"2"O + 12CO"2"
4.Determine the mass of sodium nitrate produced when 0.73g of
nickel(II) nitrate reacts with sodium hydroxide according to the following equation: Ni(NO"3")"2" + 2NaOh --> Ni(OH)"2" + 2NaNO"3"
Chemistry news on Phys.org
We have a policy that we don't do your homework for you :) here's some hints:
Not too difficult, first look up or calculate the molecular weight of Li3N (mw), then compute the number of moles Li3N that you have, you get three times the number of moles LiOH out of the reaction, convert back to grams. mw is in grams/mole, so if you know the number of grams, you divide by mw to get the number of moles (and vice versa).
First determine how H2O2 reacts with water, and do the same as above.
Same thinking here, keep track of the reaction ratios (2 C6H6 produce 12 CO2), at STP a mole of any ideal gas occupies 22.4 liters.
nickel(II) nitrate reacts with sodium hydroxide according to the following equation: Ni(NO"3")"2" + 2NaOh --> Ni(OH)"2" + 2NaNO"3" [/B]
Again, same thing.
If your chemistry textbook is any good at all, there should be stoichiometry problems similar to the ones you are working.
H2O2 yields H2O + O2 and you'll have to balance the equation first.
Here's a little trick for conversions:
GMD = grams to moles, divide
MGM = moles to grams, multiply
LMD = liters to moles, divide (22.4L)
MLM = moles to liters, multiply (22.4L)
Very good tip:
I always have the following picture in my mind:
Code:
          * mw              * 6.022 x 10^23
grams     <--       moles      -->         molecules
                      |* 22.4L (at STP)
                      V
                    liters
It is all very simple, just remember that picture and the fact that you ALWAYS have to multiply when you go from the mole to any of the other measurements. And when you want to convert something into a mole, you ALWAYS divide.
Hope that makes things clearer
9K
17K
