Solving for C: Calculating Area Between Two Functions in Calculus
  • Thread starter Thread starter CACain
    Calculus
The discussion focuses on calculating the area between the functions f(x) = 2x - 3x^3 and f(x) = c in calculus. The correct approach involves finding the points of intersection between the two curves, which serve as the limits of integration. The area is determined by integrating the difference of the two functions, specifically the integral of (2x - 3x^3 - c). Misunderstandings arose regarding the bounds of integration and the definition of the area between the curves and the y-axis.
  • Understanding of integral calculus
  • Familiarity with functions and their intersections
  • Knowledge of the concept of area under a curve
  • Ability to perform definite integrals
  • Study the method for finding intersections of functions
  • Learn how to set up and evaluate definite integrals
  • Explore the concept of area between curves in calculus
  • Review examples of integrating polynomial functions
Students and educators in calculus, mathematicians, and anyone interested in understanding the area calculations between functions.
CACain
Okay, you have 2 equations (and no points on the graph given) -- You have f(x) = 2x-3x^3 and f(x) = c. You are to find the area under the curve between those 2 functions and are to make it equal with the area between the y-axis and the 2 curves.
So, I started this problem initially by creating a graph, and putting all my points on it. I integrated both the areas with respect to x.. and I used (for the area bounded by the y-axis and the curves -- which I marked A1) the bounds 0 to 2x-3x^3.
For the second one, I don't know what bounds to use.. and I think this is where I messed up initially... I used my original bounds which are now clearly wrong...
I'm so stumped, and it's most likely something silly...
Edit: in my sleepy stuper, I forgot to include (although it may be obvious) that you are to be solving for C :)
I can't make heads or tails out of what you are saying. To start with you are given y= 2x- 3x3 and y= c and you are asked to find the area between them. Okay, that would be the integral of 2x- 3x3- c where the limits of integration are two points at which the curves intersect (NOT "0 to 2x- 3x3"). Of course for many values of c, those two curves might not intersect twice so there would be no area. I have no idea what you mean by "the area between the y-axis and the 2 curves". There is no one region "between the y-axis and the 2 curves" so there is no one area.
