Discover the Essential Orbital Velocity for Stable Earth Satellite Orbit
The discussion revolves around determining the minimum orbital velocity required for a satellite to maintain a stable orbit around Earth. The original poster notes the absence of a specified altitude, raising questions about its necessity for solving the problem.
  • Participants explore the relationship between orbital period and Earth's rotation, question the implications of escape velocity, and discuss the forces involved in maintaining a stable orbit. There are also considerations about the definitions of velocity in different contexts, such as geosynchronous orbits.
The conversation is ongoing, with participants offering various perspectives on the problem. Some suggest that assumptions about altitude and orbit type are necessary for a clearer understanding, while others provide insights into the forces at play and the calculations involved.
Participants highlight the need for clarification on the question's parameters, such as altitude and the context of velocity measurements. There is an acknowledgment that the problem may not align with introductory physics expectations.
mcolem
I don't know how to answer this question without a given altitude, but since one isn't given then I probably don't need one. Any ideas?
Determine the minimum velocity an Earth satellite must have in order to purse a stable orbit without falling to the ground.
would the period of the satellite be equal to the period of the Earth? If so it would be 24 hours or 86400 seconds (SI units) and how would that be incorporated into the problem?
I know the velocity has to be less than 11 km/sec (escape velocity).
In order to have a stable orbit, the centripetal force of the satelite must equal to the Gravitational force.
GMm/r^2=mv^2/r
For a satelite orbiting close to the earth, its radius of orbit is approximately equal to the radius of earth.
You can find v then.
This question could be phrased better. You're right, you need to know the altitude. You also need to know velocity with respect to what?
A geosynchronous satellite has a velocity of 0 with respect to the ground. The distance between your house and the satellite that feeds you TV is constant, and since average velocity = delta distance/ time, and delta distance is 0, your average velocity is 0.
But orbital velocity is different. You use circumference of the orbit / time to get orbital velocity of a circular orbit. So what is the circumference of the orbit? It depends on the altitude.
The Moon has an orbital velocity of about 1 km/s. Even if you cut it down to 0.5 km/s, it would still be in a stable, but very elliptical orbit.
The Moon is near the Earth's stability radius, which is roughly defined as 1/3 the radius of the Hill Sphere. So if you compute the orbital velocity at apogee of an object whose apogee is around 400,000 km and whose perigee is around 6478 kilometers (radius of Earth + 100 km altitude), that could be the answer. Or, like you said, 0 could be the answer too.
Ask your teacher to clarify the question.
Is there another way to answer this question with the information given in the question and any assumptions that can be made from it?
I would guess that the assumptions to be made are a low-earth circular orbit. You would not expect the points I brought up to be covered in an introductory physics class.
Just use a little algebra on the formula Harmony gave you to solve for v. Or just look up the orbit velocity formula in your book.
  • · Replies 39 ·
