Clarifications of entropy and heat transfer between reservoirs.
This discussion focuses on the calculations of heat transfer and entropy changes in a metal bar connecting two thermal reservoirs at temperatures Th = 400K and Tc = 200K. The bar, with a thermal conductivity of 406 W/(m·K), absorbs heat at a rate of 162.4 J/s from the hot reservoir and releases the same amount to the cold reservoir, resulting in a net heat absorption of 324.8 J/s. The entropy transfer rates are calculated as 0.812 J/K for the hot end and -1.624 J/K for the cold end, leading to a total entropy change of 0 J/K for the universe, which raises questions about the irreversibility of the process.
  • Understanding of thermodynamics principles, specifically the second law of thermodynamics.
  • Familiarity with heat transfer concepts, including conduction and thermal conductivity.
  • Knowledge of entropy calculations and their implications in thermodynamic processes.
  • Basic proficiency in calculus for integrating entropy changes along a material.
  • Study the derivation of the second law of thermodynamics and its implications for irreversible processes.
  • Learn about the mathematical modeling of heat transfer in solids, focusing on Fourier's law.
  • Explore advanced entropy calculations, including integrals for non-uniform temperature distributions.
  • Investigate real-world applications of thermal conductivity in materials science and engineering.
Students and professionals in thermodynamics, mechanical engineers, physicists, and anyone involved in heat transfer analysis and entropy calculations in thermal systems.
IrAlien
Hello all, I just need some clarifications on my approach to this question.
Heat is absorbed along a metal bar from a hot thermal reservoir Th to a cold thermal reservoir at temperature Tc. Apart from the ends, which are in contact with the thermal reservoirs, the bar is perfectly insulated. The bar is made of a material having a temperature-independent thermal conductivity of 406W/(m.K), Th = 400K and Tc = 200K. The cross sectional area of the bar is 5cm^2 and the length of the bar is 25cm.
a)calculate the total rate of heat absorption by the bar at the hot and cold ends. Calculate the nett rate of heat absorption by the bar over it's whole surface.
Heat absorbed(hot):
dQ(hot)/dt = lambda . dT/dx . Area
= 406.200.0.0005/0.25 = 162.4J/s
Heat absorbed(cold):
dQ(cold)/dt = -lambda . dT/dx . Area
= -162.4J/s
..S(outflow)......S(inflow)..
Cold reservoir <-----<-----< Hot reservoir
.'. dQ(nett)/dt = Sinflow - Soutflow = 162.4-(-162.4) = 324.8J/s
b)calculate the rate of entropy transfer into the bar at the hot and cold ends.
Entropy(hot)
dS/dt = 1/Th . dQ(reversible)/dt
= 1/Th . 324.8 = 324.8/400 = 0.812J/K
Entropy(cold)
dS/dt = -1/Tc . dQ(reversible)/dt
= -1/200 . 324.8 = -1.624J/K
c)calculate the rate of entropy production inside the bar.
dS/dt = lambda . dT/dx. A (1/Tc - 1/Th)
= 0.406J/K
d)calculate the rate of change of entropy of the universe (the bar and 2 reservoirs) and show that it satisfies the second law of thermodynamics.
dS/dt = dS(external)/dt + dS(internal)/dt
dS(external) = lambda . dT/dx . A (1/Th - 1/Tc)
= -0.406J/K
dS(internal) = entropy production inside the bar = 0.406J/K
.'. dS/dt = -0.406 + 0.406 = 0 J/K
Now, I thought that the second law of thermodynamics says that that should be greater than 0 in a irreversible process(Is this irreversible?)... Why did I get 0? Any one that can explain it to me would be kindly appreciated.
Heat absorbed(hot):
= -162.4J/s
I think this should be 0. The heat in = heat out so there is no net rate of heat absorption.
= -0.406J/K
The heat flow out of the hot reservoir is negative and the heat flow into the cold reservoir is positive.
As you correctly state, the rate of change in entropy of the universe is the sum of the rates of change of entropy of the hot and reservoirs and bar.
[tex]\Delta S_{hot}/dt = \frac{d}{dt}Q_{hot}/T_h = -162.4/400 = -.406 J/Ksec[/tex]
[tex]\Delta S_{cold}/dt = \frac{d}{dt}Q_{cold}/T_c = +162.4/200 = +.812 J/Ksec[/tex]
[tex]\Delta S_{bar}/dt = .406 J/Ksec[/tex]
[tex]\Delta S_{universe}/dt = -.406 + .812 + .406 = .812 J/Ksec[/tex]
AM
= 0.406J/K
I don't think this is correct.
The rate of entropy 'production' in the bar is the integral of ds along the length of the bar. For a 'slice' of width dx, the entropy change is:
[tex]dS = dQ_{in}/T - dQ_{out}/(T-dT)[/tex]
Since both heats are the same:
[tex]ds = (Q(T-dT)/T(T-dT)) - QT/T(T-dT) = -QdT/T(T-dT) = -QdT/T^2[/tex]
[tex]dS/dt = d/dt\int_{T_c}^{T_h} -QT^{-2} dT[/tex]
So work that integral out to find the rate of entropy production in the bar.
AM
