Volume of Revolution: Finding % Filled in Bowl
  • Thread starter Thread starter dan greig
    Revolution Volume
The discussion revolves around calculating the volume of a hemisphere and determining the percentage of the bowl that is filled with water. The original poster has identified the volume of the hemisphere but seeks assistance in finding the x value corresponding to a water height of 4.5 cm in a hemisphere with a radius of 9 cm.
  • Participants discuss the method of integrating the outline of the bowl to find the volume filled. Questions arise regarding the axis of rotation and the limits of integration. There is also confusion about the function to use based on the given equation of the circle.
The conversation is ongoing, with participants providing insights into the integration process and questioning the setup of the problem. Some guidance has been offered regarding the integration limits and the function to use, but there is no explicit consensus on the approach yet.
Participants are working under the constraints of the problem as stated, including the specific dimensions of the hemisphere and the height of the water. There is also a focus on ensuring the integration reflects the physical scenario of filling the bowl from the bottom up.
dan greig
I have a question about finding the volume of a hemisphere, I've got that bit sorted but the next bit asks,
if the bowl is partially filled what percentage of the bowl is filled.
I think i understand the method but i need to find the x value when the bowl is filled 4.5cm of a hemisphere of radius 9cm
Have you rotated about the x-axis or y-axis?
~H
You have the equation of the shape (outline) of the vessel, you have the height (plane) it needs to be filled to...
ie. integrate the outline^2 between 0 and this height and times by pi.
Of course - you want the height:redface: but from what you write... this is 4.5cm ?!?
about the y axis.
the shape is a circle - x^2 + y^2
is this what you mean by outline?
the equation i have been given is, x^2 + y^2 = 81
y=f(x)
then [tex]\pi\int_0^{4.5}f(x)^2dx[/tex] should be your answer.
from my immediate thought...
No, I don't think you have the limits of integration right. Since the water will "fill" from the bottom of the circle up, the intgration should be from x= 9 to x= 4.5 (or, more correctly, -9 to -4.5 so the water doesn't spill out!). Also the problem asked for the percentage that was filled. If the water is 1/2 up the side of the bowl, what percentage is filled?
if i use -9 and -4.5 as the limits of integration, what is the function of x -
f(x) i use?
as i have been given the equation for a circle it has confused me a little.
Úsing my above equation with...
[tex]f(x)=(81-(x-9)^2)^{1/2}[/tex] as the outline should work.
ie. [tex]\pi\int_0^{4.5}(18x-x^2)dx[/tex]
Giving a numerical value of the water filling 31% of the hemisphere - which seems about right...
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 16 ·
14K
