Vectors - show that the lines intersect
  • Thread starter Thread starter smn
    Lines Vectors
The original poster is working on a problem involving vector equations to determine if two lines intersect. The lines are given in parametric form, and the task is to show that they intersect by finding values for the parameters s and t that satisfy the equations derived from the vector components.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the need to find values for s and t that satisfy three vector component equations. There are suggestions to use simultaneous equations to solve for these parameters and check if they satisfy all equations. Some participants also question the implications of having a common point for intersection.
The discussion is active, with participants providing guidance on how to approach solving the equations. There is recognition of the need to check if the values found for s and t satisfy all three equations. Some participants are exploring alternative methods to demonstrate intersection without explicitly solving for s and t.
Participants note that the problem involves advanced concepts in vector mathematics, including parametric vector forms and the potential use of coplanarity and parallelism to show intersection.
smn
Hi, I'm currently revising for a maths exam and I'm stuck on the following question:
Show that the lines:
r = (i+j+k) + s(i+2j+3k)
r = (4i+6j+5k) + t(2i+3j+k)
Intersect.
My work so far:
Let (i+j+k) + s(i+2j+3k) = (4i+6j+5k) + t(2i+3j+k)
So (i) 1+s = 4+2t
(j) 1+2s = 6+3t
(k) 1+3s = 5+t
I'm unsure where to go from here, any help would be appreciated.
Regards
smn
You have to find values for s and t and show that they satisfy all three vector component equations (i,j & k)
~H
So, you have three equations that must be satisfied for an intersection.
Is there a pair of values (s,t) that satisfies all three equations simultaneously?
[Try using, say, equation (i) with equation (j), then the result with (k) etc...] Once you determine a pair (s,t), check that it satisfies each equation.
Well, if they intersect, then they must by necessity have a point in common. You started on that above. If they have a point in common, what can you say about possible solutions to the system of equations you found?
Thanks for the prompt replys.
I realize that you have to solve for s and t and these values should equal if the lines intersect.
I was unsure what to do next with the 3 equations in order to solve for s and t.
I'm now going to try using simultaneous equations, as mentioned, to try and solve for s and t.
Regards
smn
That's the way to go!
~H
You have two variables s and t. You should be able solve two of the equations for them. Do those two values also satisfy the third equation?
Yes, i worked out that s=1 and t= -1. I then sub'd these values into the 3rd equation and it satisfied this also ( 4=4).
Thanks for all your help
Regards
Sam
Now, the follow-up question...
can you show that there exists an intersection WITHOUT solving explicitly for s and t?
Using pre-calculus methods? Only way I can think of is to show they are coplanar and not parallel.
Are use of the dot- and cross-product operations considered pre-calculus?
Note that the OP has already written lines in parametric vector form:
[tex]\vec A=\vec A_0 + s\vec U[/tex]
[tex]\vec B=\vec B_0 + t\vec V[/tex]
which is already somewhat advanced by introductory standards.
It wan't when I was in HS, but that was back in the late 70s.
