Estimate Spring and Damping Constants of 1700kg Automobile
  • Thread starter Thread starter mb85
    Constant Damping
The discussion focuses on estimating the spring constant (k) and damping constant (b) for the suspension system of a 1700 kg automobile. The spring constant is calculated to be 1281.5 N/m based on the sag of 13 cm when the chassis is placed on the suspension. The damping constant is more complex to determine, with the formula W' = √(K/m - b²/4m²) suggested for calculations. Participants in the discussion highlight the need for detailed calculations to arrive at the correct damping constant.
  • Understanding of Newton's laws of motion
  • Familiarity with spring mechanics and Hooke's Law
  • Basic knowledge of oscillatory motion and damping
  • Proficiency in algebraic manipulation of equations
  • Study the derivation of the spring constant using Kx = mg
  • Learn about the principles of damping in mechanical systems
  • Explore the calculation of natural frequency in oscillatory systems
  • Investigate the effects of mass distribution on suspension systems
Automotive engineers, mechanical engineers, physics students, and anyone involved in vehicle suspension design and analysis.
mb85
The suspension system of a 1700 kg automobile "sags" 13 cm when the chassis is placed on it. Also, the oscillation amplitude decreases by 62% each cycle. Estimate the values of (a) the spring constant k and (b) the damping constant b for the spring and shock absorber system of one wheel, assuming each wheel supports 425 kg.
Kx = mg
K = 1281.5 N/m
But the damping constant i am having trouble with.
W' = Square root (K/m - b^2/4m^2) is the formula i think i use?
= kg/s
but both answers are wrong
Perhaps if you showed your calculations we could help.
~H
