| Thread Closed |
Throttling Process |
Share Thread |
| May5-06, 06:28 AM | #1 |
Throttling Process
dear all
What is the throttling Process? what is Joule homson Effect? |
| May5-06, 06:50 AM | #2 |
Recognitions:
| May5-06, 02:28 PM | #3 |
A throttling process is a process that is isenthalpic. Thus, [tex] h_1 = h_2 [/tex]. This means that the following is also true, [tex] u_1 + P_1 v_1 = u_2 + P_2 v_2 [/tex]. So if you drop pressure in a throttling value, you increase the internal energy, and vise versa.
The Joule -thomson- effect deals with the fact that as you expand a gas it looses temperature. Note that for hydrogen; however, it gains temperaturee as it expands. This makes hyrdogen particularly dagnerous. |
| May7-06, 11:36 PM | #4 |
Throttling Process
Pressure drops in CNG kit Pressure regulator from 300 bar to 4 bar in 1st chamber due to expansion is it throttling process? temperature also drops in it.
| May7-06, 11:52 PM | #5 |
Yes, that is exactly what it is.
Edit: wait, what do you mean by expansion? Is it going through a nozzle? |
| May8-06, 01:51 AM | #6 |
no it is going throug valve (sloninoid valve) from storage cylinder through high pressure pipe into solinoid valve and then in the 1st stage chamber of pressure regulator.
| May8-06, 11:30 AM | #7 |
Yes, it is a throttling valve.
| May8-06, 10:59 PM | #8 |
what is the value of joule-thomson coefficient for methane
| Thread Closed |
Similar discussions for: Throttling Process
| The principle behind throttling valves | Mechanical Engineering | 36 | ||
| SOI process | Electrical Engineering | 4 | ||
| joule thomson throttling | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Gas process | Introductory Physics Homework | 5 | ||
| Proof that a stochastic process isn't a Markov Process | Set Theory, Logic, Probability, Statistics | 4 | ||
