Write an equation for the circle
  • Thread starter Thread starter Aya
    Circle
The discussion revolves around writing equations for circles based on given endpoints of a diameter and the context of circular waves created by a stone dropped in a lake. The subject area includes geometry and algebra, particularly focusing on the properties of circles and simplification of square roots.
  • The original poster attempts to derive the equation of a circle from the endpoints of a diameter and questions the validity of their result compared to a provided answer. They also explore the simplification of square roots and the concept of rise and run in relation to coordinate axes.
Participants are engaging in clarifying the original poster's approach to the problem, with some confirming the correctness of their calculations while others question the reference answer from the book. There is an ongoing exploration of how to simplify square roots and the implications of axis orientation on the concept of rise over run.
There is mention of a potentially outdated answer in the book, leading to uncertainty about the correctness of the provided solution. The discussion also highlights the need for careful consideration of axis setup in mathematical problems.
Aya
Hi, I need help with these questions
Given the endpoints of a diameter, write an equation for the circle.
a) (-3,5) and (1,3)
I tryed this
m= (x1+x2)/2, (y1+y2)/2
= (-3+1)/2 , (5+3)/2
= -2/2, 8/2
= (-1,4)
( x-h)^2 + (y-k)^2=r^2
(x+1)^2 + (y-4)^2=r^2
(1+1)^2 + (3-4)^2=r^2
(2)^2 + (-1)^2=r^2
5=r^2
so, (x+1)^2 + (y-4)^2 = 5
but, this answer in the back of the book is different so can someone tell me what to do?
and
1. how do you simplify root 50
2. is rise y and run x?
when a stone is dropped in a lake, circular waves or ripples are created. The enrey point of the stone marks the center of the circles. Suppose the radious increases at the reate of 20cm/s. write anequation for the outermost circle 2.5s after the stone hits the water.
20*2.5=50cm
X^2 + Y^2=50^2
X^2 + Y^2=2500
is that right?
That answer looks right to me...What is the answer that is given?
1) To simplify the square root of 50, can you think of a way to write 50 as the product of two numbers, one of which is a perfect square?
2) Yes. You have to be careful though because it really depends on how you set up your axis. There's nothing stopping you from writing a line in the form of x=my+a, in which case the "rise over run" is a bit misleading if you set up your axis as y vertically and x horizontally.
^ thanks
I thought the two numbers were 25 and ...but how do you rght that? 2root25
simplify es to 2root5, but that's wrong right?
the answer in the book was x^2+y^2=49
Are you sure you're checking the answer for the right problem?
You are right that you can write 50 as 25*2
[tex]\sqrt{50}[/tex]
[tex]\sqrt{25\cdot 2}[/tex]
Can you see what to do from there?
ya, the book is old maby that answer is wrong.
root 25 is 5 soo..
5root2?
Aya said:
root 25 is 5 soo..
5root2?
Yep, that's correct.
k thanks for you help
  • · Replies 16 ·
