How Can the Emission Spectrum of a Gas Be Manipulated?
The discussion centers on manipulating the emission spectrum of gases, specifically using an argon gas laser. By adjusting the frequency of the pumping current and the voltage, one can influence the energy levels of the electrons, thereby stimulating specific emission lines. The conversation also touches on the spectral bandwidths of excitation and emission lines, noting that these lines are not absolute but have widths that allow for some tolerance in energy transitions. This variance is crucial for applications like atomic clocks, which rely on precise frequency locking.
  • Understanding of argon gas lasers and their emission characteristics.
  • Knowledge of electron energy levels and excitation processes.
  • Familiarity with spectral bandwidth concepts in quantum mechanics.
  • Basic principles of laser tuning and dye lasers.
  • Research the principles of laser tuning in dye lasers.
  • Explore the relationship between pumping current frequency and electron excitation in gases.
  • Study the effects of voltage on emission line intensity in gas lasers.
  • Investigate the statistical distribution of energy transitions in quantum systems.
Physicists, optical engineers, and anyone involved in laser technology or spectroscopy who seeks to understand the manipulation of gas emission spectra.
eeka chu
Is there anyway of manipulating the emission spectrum of something like a gas by pumping it with a specific input?
An argon gas laser, for example, will have lots of emission lines. Is there anyway of singling out groups of those lines without changing the gas? I would imagine such a method would have something to do with the frequency of the pumping current, the energy levels of the electrons or some of both; e.g. by increasing the voltage you'd get more high energy electrons which would seem to suggest more of the higher energy lines would be then be stimulated.
Also, as a kind of side question, what kind of spectral bandwidths can excitation / emission lines have? If the lines were absolutes, things like atomic clocks would have problems locking the frequency - well, you'd need an absolutely identical excitation frequency - and a whole load of other things relying on such pumping wouldn't work very well, if at all. So the lines have widths, and that implies that there is some degree of 'tolerance' if you like on the energy taken up and re-emitted by electrons as they move between levels, that the values aren't perfectly discrete; which then, of coarse, allows their input / output lines to be thicker than single, absolute frequencies. For example... I might have a line that centres at 380nm but it also has a thickness that stretches a few nm either side of it. Those nm would indicate that there is a slight degree of variance occurring in the energy transitions that create the line. I'm going to take a guess that those variances follow a bell shaped curve of distribution a la energy per particle against temperature.
Thanks!
John
I know that dye lasers are fairly tunable, but not much about the specifics.
