Thread Closed
Kirchhoff's Rules
Share Thread Thread Tools
May11-06, 07:19 PM   #1
Kirchhoff's Rules
I understand (or at least thought I did) :D Kirchhoff's rules. When I got to this circuit; however, I got a wee bit confused. The arrows indicate where I placed my three arbitrary currents. When writing equations for the two smaller loops (the ones on the left), I didn't know which current to use for the middle portion (in red). Should I add another current here?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
May12-06, 01:44 PM   #2
Mentor
I recommend that you use the branch current method to solve these kinds of problems: Assign each distinct branch its own current. (In this circuit, I see 6 branches.)
May12-06, 01:52 PM   #3
When does current change?
A good way to think of current is as water flowing through a pipe. Think of the voltage source as a faucet pumping out water. So what would happen if you had a pipe that forked? The water would reach it and the water would split, a portion going one way and another portion going the other.
A more mechanical way of thinking of it is. Current changes when you have elements in parallel. What is the definition of parallel?
A loose definition is when two elements share start/end nodes.
So if you label all your nodes {A,B,C,...} and then arbitrarily assign a current from node A to B, A to C, ... then you will get your answer.
Thread Closed
Thread Tools
Similar Threads for: Kirchhoff's Rules
Thread Forum Replies
Kirchhoff's Rules Introductory Physics Homework 2
Kirchhoff's Rules? Introductory Physics Homework 1
Kirchhoff's rules Advanced Physics Homework 1
Kirchhoff's Rules help Introductory Physics Homework 8
Circuits with Kirchhoff's rules Introductory Physics Homework 11
