Calculating Strength of Hollow Shaft with Notch & Holes
The discussion revolves around calculating the strength of a hollow shaft with specific dimensions and features, including a notch and drilled holes. Participants explore how these factors affect the shaft's strength under torsion and bending loads, with references to stress concentration factors and relevant literature.
  • Experimental/applied
  • One participant notes that the strength of the hollow shaft is estimated to be reduced by about 15% compared to a solid shaft, seeking further calculations for the impact of the notch and holes.
  • Another participant suggests using stress concentration factors to account for the effects of the holes and notches, referencing R. E. Peterson's work on the topic.
  • A different participant mentions that Roark's Formulas for Stress and Strain contains relevant data on stress concentrations for notches and holes, indicating specific tables that could be useful.
  • There is a discussion about the average length of shafts, with conflicting claims about whether it is measured in inches or centimeters, and how this might affect experimental results.
  • One participant emphasizes that a wider shaft may perform better and yield more consistent results than a longer shaft, suggesting that length may not be a critical factor in some methods.
Participants express differing views on the average length of shafts and its relevance to the experiment. There is no consensus on the exact impact of the notch and holes on the strength of the hollow shaft, as various methods and references are proposed without agreement on a definitive approach.
Participants reference specific texts and tables for stress concentration factors, indicating that the calculations may depend on the definitions and assumptions used in those sources. The discussion also highlights potential misconceptions regarding measurement units.
elmariachi
Hi all,
I have a hollow shaft of 2" outside dia to 1.25" inside dia, about 1.5 ft in length.I also have a notch going around the outside periphery of the shaft. The shaft also has 2 holes drilled tranversely through the shaft
The shaft will be rotating and will have torsion and probably bending load. I already calculated that the strength of this hollow shaft will reduce by about 15% compared to a solid 2" shaft.How can I further calculate the reduction in strength taking into consideration the drilled tranverse holes & the notch.Thanks in advance.
john
The stress resulting from holes and notches in a shaft are generally handled by stress concentration factors, and the classic work is that of R. E. Peterson, "Stress Concentration Factors," Wiley, New York, 1974.
Unfortunately, I do not have a copy at the moment.
Some texts, like Richard G. Budynas's "Advanced Strength and Applied Stress Analysis" may have graphs or tables taken from Petersen's text (which does have stress concentration factors for semicircular notches in a solid shafts) or journal articles, particularly in Machine Design, in which Petersen published a series of articles on stress concentration factors in Feb-July, 1951.
This might be of use -
http://www.machinedesign.com/asp/index.asp?
I believe it is the same journal, but I have not referenced it recently.
I can't type all of it here, but if you have access to Roark's Formulas for Stress and Strain, stress concentrations that you require are in table 37, pages 737 and 739 in my copy deal exactly with your situation.
For the notch, it it is a 3rd order polynomial that is a function of notch depth and notch radius (makes sense).
For the hole is another 3rd order polynomial that is a function of hole radius and shaft OD.
what is the average shaft length? I am doing an experimental plan.
is it around 7 inches?
help much appreciated
I have the 7th edition of Roark's Forumulas for Stress and Strain.
The data that Fred described are in Table 17.1 on page 790-792, and show stress concentration factors for bending and torsion.
the average shaft length is 7 cm, not inches. a common misconception. 7 inches is aroundabout 3 cm. it depends what instruments shaft youre measuring, and whether length really plays a key part. for many methods a wide shaft performs better and gives more consistent results than a long shaft. bear this in mind for your shaft experiment!
enjoy
xxxx Gareth
oh and bending will affect a wide shaft less so take this into account.
enjoy
xxxx Gareth
oh thanks! i remember hearing about the length but not having actually measured one before, i was lost! :-)
11K
