How much total mechanical work does a eight lifter do in 10 repetitions
  • Thread starter Thread starter ShakeWell
    Mechanical Work
The total mechanical work done by an eight lifter performing 10 repetitions of lifting and lowering 200 kg to a height of 1.0m is definitively zero. This conclusion is based on the principle that work is defined as the product of force and displacement in the direction of that force. Since the final displacement is zero—returning the weight to its initial position—the net mechanical work is zero. Although the muscles exert force, the work done by them is not classified as mechanical work in this context due to the conservative nature of gravitational force.
  • Understanding of mechanical work and its definition in physics
  • Knowledge of potential energy concepts
  • Familiarity with conservative and non-conservative forces
  • Basic principles of force and displacement
  • Research the concept of conservative versus non-conservative forces in physics
  • Explore the relationship between work, energy, and displacement in mechanical systems
  • Study the implications of lifting techniques on muscle exertion and energy expenditure
  • Investigate how different assumptions affect calculations of mechanical work in various physical scenarios
Students studying physics, fitness professionals analyzing lifting techniques, and anyone interested in the mechanics of physical work and energy expenditure.
ShakeWell
ok, tell me if I'm wrong:
the questions asks:
How much total mechanical work does a eight lifter do in 10 repetitions of lifting (and lowering) 200 kg to a height of 1.0m?
I'm thinking, since the final total displacement is zero, the answer is 0 right?
The "total mechanical work" is the change in potential energy (and here, since the weight is returned to its initial position that is 0) only for a "conservative" force (i.e. no friction). Of course, gravity is conservative but, in general, the force supplied by muscles is not. I don't think it is possible to give a definite answer without knowing precisely what assumptions are made. Exactly what the total mechanical work is depends a lot on how it is moved. Many texts would not call the work the muscles have to do "mechanical" work. While I think there is a very good argument for "0 work", I recommend you discuss this with your teacher!
Yes, you are correct. The total mechanical work done by the eight lifter in 10 repetitions would be 0, since the final displacement is zero. This is because work is defined as the product of force and displacement in the direction of the force. Since the weight is being lifted and lowered to the same height, the total displacement is zero and therefore the total work done is also zero.
  • · Replies 24 ·
  • · Replies 56 ·
