Does Convergence at Zero Imply Global Convergence for Power Series?
  • Thread starter Thread starter Hummingbird25
    Convergence Series
The discussion revolves around the convergence of power series, specifically questioning whether convergence at a single point (x converging towards zero) implies convergence for all real numbers x. Participants are exploring concepts related to the radius of convergence and the behavior of series.
  • Participants are attempting to clarify the meaning of convergence in the context of power series and questioning the implications of convergence at a specific point. There is discussion about the definition of the set of real numbers and the ratio test as a method for determining convergence.
Some participants have provided clarifications regarding terminology and concepts, such as the radius of convergence and the ratio test. There appears to be a mix of interpretations regarding the original poster's question, with no explicit consensus reached on the implications of convergence at zero.
There is confusion regarding the phrasing of the original question, particularly the use of "x converging towards zero" and the implications of this statement on the convergence of the series for all real numbers.
Hummingbird25
Dear all
If a series e.g. a power series results in x convergering towards zero, can then one conclude that this series converge for all number if let's x belongs to R?
Sincerely Yours
Hummingbird25
what do you mean by R? the ratio between terms?
I believe Hummingbird was referring to the set of real numbers (often denoted by R). The answer to the question (if I read it correctly, I had to read it a few times) is no also, look up "radius of convergence".
Hummingbird25 said:
Dear all
Sincerely Yours
Hummingbird25
This makes no sense at all. "A power series results in x converging towards zero"? First of all, x does not "converge" toward anything. It is a variable. Second, I don't know what you mean by saying "a power series results" in that.
If I really had to guess, I would guess you are asking about the "ratio test". If, for any series of positive numbers
[tex]\Sum_{n=0}^\infnty a_n[/tex] the sequence [tex]\frac{a_{n+1}}{a_n}[/tex] converges to any number less than 1, then the series converges.
From that it follows that if, for the power series [tex]\Sum_{n=0}^\infty a_nx^n[/itex] and some specific x, the ratio [tex]\left|\frac{a_{n+1}}{a_n}\right|\left|x\right|[/tex] is less than 1 then the series converges for that x. In particular, if [tex]\left|\frac{a_{n+1}}{a_n}\right|[/tex] converges to 0 then the above will converge to 0 <1 for <b>all</b> x and so the power series converges for all x.[/tex]
  • · Replies 22 ·
