Combustion Equation: C8H18 + O2 + N2 = CO2 + H2O
  • Context: Graduate
  • Thread starter Thread starter radwa
    Combustion
The combustion of octane (C8H18) with 200% theoretical air produces a specific molal analysis of combustion products, which includes 8 moles of CO2 and 9 moles of H2O at a pressure of 0.1 MPa. The balanced combustion equation is C8H18 + 12.5(2)O2 + 12.5(2)(3.76)N2 = 8CO2 + 9H2O + 12.5O2 + 94N2. The dew point of the products is determined by calculating the partial pressure of water vapor, which is derived from the mole percent of water in the combustion products. The choice of the balanced equation significantly affects the results of the partial pressure calculations.
  • Understanding of combustion chemistry and stoichiometry
  • Familiarity with the concept of theoretical air in combustion
  • Knowledge of dew point calculation and saturation temperature
  • Basic principles of gas laws and partial pressures
  • Study the principles of stoichiometric combustion and its applications
  • Learn how to calculate dew point and saturation temperature in combustion products
  • Explore the effects of varying air-fuel ratios on combustion efficiency
  • Investigate the role of nitrogen in combustion reactions and its impact on emissions
Chemical engineers, combustion scientists, and students studying thermodynamics and chemical reactions will benefit from this discussion.
radwa
Will you please help me...
It is required to determine the molal analysis of the products of combustion when C8 H18 is burned with 200% theoretical air, and determine the dew point (saturation temperature corresponding to the partial pressure of water present in this equation) of the products if the pressure is 0.1 MPa
This is the combustion equation the book used to solve this problem with
C8 H18 + 12.5(2)O2 +12.5(2)(3.76)N2 =8CO2 +9H2 O+12.5O2 +94N2
My question is when balancing this equation we might have chosen to write it as
C8 H18 + 6.75(2)O2 +6.75(2)(3.76)N2 =8CO2 +9H2 O+O2 +50.76N2
But if we changed the equation like this, in getting the partial pressure of water, instead of calculating it by obtaining the mole percent of the water from the first equation which is 7.29% and multiplying it by 0.1 MPa to have apartial pressure of 7.29 KPa we will get a very different result using the second equation .How do we know that we have to write the first and not the second equation?
Science news on Phys.org
(snip)
How do we know that we have to write the first and not the second equation? [/B]
9K
14K
10K
  • · Replies 44 ·
