Eccentricity of elliptical path of earth
The discussion revolves around the eccentricity of Earth's orbit and its implications for the ratio of maximum to minimum speeds in that orbit. Participants are exploring the relationships between the semi-major and semi-minor axes, as well as the distances at aphelion and perihelion.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants present their calculations regarding the ratio of maximum and minimum speeds, questioning the assumptions made about the relationship between speed and the axes of the ellipse. Some suggest that the speeds should be related to the distances at aphelion and perihelion instead.
There is an ongoing exploration of different interpretations of the problem, with some participants providing alternative approaches and corrections to the original assumptions. Guidance has been offered regarding the correct relationships to consider, but no consensus has been reached.
Participants are working within the constraints of the problem as posed, including the provided eccentricity value and the need to reconcile their calculations with a textbook answer. The discussion highlights the importance of understanding the geometry of elliptical orbits in relation to speed.
Amith2006
Sir,
The eccentricity of Earth's orbit is 0.0167. What is the ratio of its maximum speed to its minimum speed in its orbit?
I solved it in the following way:
Let its maximum and minimum speed be v1 and v2 respectively. Let a and b be the semi length of the major and minor axis respectively. Let e be its eccentricity.
v is inversely proportional to a and b. I took this assumption because at points closest to the centre of the elliptical path the velocity is maximum.
Hence,
v1/v2 = a/b
Now for an ellipse, (1 – e^2) = (b/a)^2
By solving I get,
a/b = 1.00014
Therefore,
v1/v2 = 1.00014
But the book answer is 1.033. Is there any mistake?
Amith2006 said:
Sir,
Hence,
v1/v2 = a/b
By solving I get,
a/b = 1.00014
Therefore,
v1/v2 = 1.00014
Your mistake is in assuming that the v1 and V2 are porportional to a and b. They are instead proportional to rap and rper, which are the aphelion and perhelion of the orbit, the furthest distance and closest approach the orbit has to the Sun. (these are not equal to a and b. Since the Sun is located at one of the foci of the elipse and not the center.)
The aphelion is found by
[itex]r_{ap}= a(1+e)[/itex]
and the perhelion by
[itex]r_{per}= a(1-e)[/itex]
Amith2006 said:
Sir,
Hence,
v1/v2 = a/b
By solving I get,
a/b = 1.00014
Therefore,
v1/v2 = 1.00014
But a/b is not the ratio of maximum to minimum radii. A planet prescribes an orbit about the sun with the sun at one of the focii. So the ratio of max radius to min radius is: (1+e)/(1-e), which is 1.0340
Since angular momentum is conserved:
[tex]mvr =[/tex] constant
Therefore: [itex]v \propto 1/r[/itex]
So this is also the ratio of maximum to minimum speeds.
AM
You can prove yourself that
[tex]V_{max} = \sqrt{\frac{GM}{a}\left(\frac{1+e}{1-e}\right)}[/tex]
[tex]V_{min} = \sqrt{\frac{GM}{a}\left(\frac{1-e}{1+e}\right)}[/tex]
This would be a good exercise in Kepler's Laws and elliptic orbits for you :smile:
Andrew's approach to your question can also be derived from Kepler's second law as follows:
[tex]\frac{dA_{ap}}{dt}=\frac{dA_{per}}{dt}[/tex]
[tex]\frac{r_{ap}ds_{ap}}{2dt}=\frac{r_{per}ds_{per}}{2dt}[/tex]
[tex]r_{ap}v_{ap}=r_{per}v_{per}[/tex]
11K
