Calculating the Rate of Water Level Increase in a Trapezoid-Shaped Trough
The problem involves calculating the rate of water level increase in a trapezoid-shaped trough, with specific dimensions and a constant water inflow rate. The original poster attempts to apply the volume formula for a trapezoid but expresses uncertainty about their approach.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the differentiation of the volume formula and the dependency of variables on time. Questions arise about expressing dimensions in terms of height and the relationship between width and height using similar triangles.
Participants are actively exploring different interpretations of the problem and questioning the assumptions made about the variables involved. Some guidance has been offered regarding the relationship between height and width, but no consensus has been reached on a definitive method.
There is a focus on the need to clarify which dimensions of the trapezoid are variable with time, and the original poster expresses confusion about the correct application of the volume formula in relation to changing dimensions.
cscott
A water trough is 6 m long and has a cross-section in the shape of an isosceles trapezoid (dimension shown in the diagram.) Water is being pumped into the trough at a rate of 0.5 m^3/min. How fast is the water level rising when it is 0.5 m deep.
AFAIK the volume of a trapazoid like this should be
[tex]V = \frac{1}{2}h(a + b)l[/tex]
where a, b, and l are all given constants, therefore
[tex]\frac{dV}{dt} = \frac{1}{2}\frac{dh}{dt}(a + b)l[/tex]
But this can't be right. I don't think I'm approaching this correctly...
What do you personally think you're doing wrong? you should be very careful to note that V = 1/2h(a+b)l makes no distinction as to what is actually a function of t, although you try to differentiate with respect to t the height later. Yes that's the volume of a filled container, but differentiating h with respect to t would yield 0 because it is a constant. Perhaps construct the volume of a trapezoid whose height is dependent on time t.
Would I have to express all the other variables in terms of h?:bugeye:
No, no. Just think about the shape of a volume that was being filled up by water and what dimensions are variable with time. Certainly the height filled with water will be variable with time, but what about the width of the surface? Obvioously the base of the trough will not change though.
I'm assuming I can relate the width to height using (1/4)w/h = 0.6/0.9 (i.e. similar triangles)?
Test it out :). I suggest using extreme cases such as where h = 0 what is w? (better equal the width of the base)
Well mine isn't going to work because at h = 0, w = 0.
Trying w = 1.2/0.9h + 0.6 ...
Woot, I got it. Thanks for your help/patience!
9K
