Why Does Less Foam Form in a Soda Cup?
  • Context: High School
  • Thread starter Thread starter daniel_i_l
The discussion centers around the phenomenon of reduced foam formation when refilling a cup with soda, exploring various factors that might influence this observation. Participants consider aspects related to the physical properties of the soda, the condition of the cup, and the pouring technique.
  • Some participants suggest that the temperature of the cup may affect foam formation, although this is questioned by others who report similar results regardless of temperature.
  • One participant proposes that systematic errors in pouring technique, such as the angle of the bottle, could influence the amount of foam produced.
  • Another viewpoint is that the cleanliness of the cup affects foam, with some arguing that a clean glass produces less foam due to fewer nucleation sites available for bubble formation.
  • It is mentioned that soda may lose carbonation over time after being opened, which could lead to less foam upon subsequent pours.
  • Participants discuss the effect of pouring into a wet versus dry glass, suggesting that a wet glass reduces foam due to the coating of liquid blocking nucleation sites.
  • Some participants challenge the idea that dirt causes foam, arguing that the presence of liquid in the cup may be more significant in reducing available nucleation sites.
Participants express multiple competing views regarding the factors influencing foam formation, with no consensus reached on the primary cause of the observed phenomenon.
Participants note various assumptions, such as the condition of the soda and the cleanliness of the cup, which may impact the results but remain unresolved in the discussion.
daniel_i_l
Why is there less foam the second time you fill a cup with soda than the first time.
At first I thought that it had to do with the temperture of the cup changing(it cools down after filling it the first time) but I get the same resault with warm coke or with a cold cup?
Any ideas?
Thanks.
There could be many "systematic errors." If you're pouring from the same bottle for both the first and second cups, it's possible that the way you're holding the bottle the second time (it is lighter and needs to be held at a different angle) is affecting the results.
You'd really need to start over with a totally fresh bottle of soda with each "run" of the experiment, to isolate the cup as the only variable.
- Warren
Any ideas?
Thanks.
I think the foam is caused by dirt or dust on the surface of the cup.
I think there is less foam with a really clean glass.
When you refill the cup, there is a coating of soda on the surface, which probably keeps the new soda from interacting with the surface.
If you're pouring from a bottle (as opposed to filling from a fountain), it's possibly just the soda in the bottle going flat (every time you open the bottle, the soda outgases some) with time of exposure and number of prior openings.
Why would dirt cause foam? That doesn't make any sense.
The obvious answer is that when you first open the bottle of soda it's at its maximum carbonation level. It's also possible that the change in pressure when you first open it allows more bubbles to be released so if you pour it right away you get more foam. Once you let it sit for a bit, that initial level level of carbonation isn't there anymore so you don't get as much foam. (Which is pretty much what Gokul said)
Pouring into a wet glass makes much less foam than pouring into a dry glass, regardless of the condition of the bottle. Try it by wetting the glass with water, and using a fresh bottle.
Not sure of why though. Something to do with nucleation of bubbles from the glass surface, purely as a guess.
It makes perfect sense if you understand how bubbles are formed in liquids. Google or Wiki "nucleation sites"
Personally, I think that a cup that has previously had liquid in it has been "wetted" - all its nucleation sites are covered or blocked with a thin layer of liquid. Less available nucleation sites, less foam. [Edit: ... as I now see brewnog points out before me]
Yeah I made that comment before thinking. I guess what I wanted to say was that the amount of dust in a glass wouldn't be enough to make that big of a difference.
10K
  • · Replies 33 ·
  • · Replies 27 ·
  • · Replies 47 ·
  • · Replies 19 ·
