What Is the Purpose of Op Amps?
  • Thread starter Thread starter barneygumble742
    Amps Op amps
The discussion revolves around the purpose and applications of operational amplifiers (op-amps) in electronics. Participants explore their functionality, characteristics, and advantages in various contexts, including analog electronics and signal processing.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant expresses confusion about the purpose of op-amps and seeks a simplified explanation.
  • Another participant describes op-amps as high gain differential amplifiers, highlighting their input characteristics, gain-phase characteristics, and output drive capability.
  • A different participant lists several applications of op-amps, including their use as comparators in sensors, their stability due to negative feedback, and their linear gain properties.
  • One contributor emphasizes that op-amps simplify the design of amplifiers compared to discrete components, making it accessible for those without specialized training in analog electronics.
  • A suggestion is made to refer to "cookbook" texts for practical insights into op-amp applications.
Participants generally agree on the usefulness of op-amps and their role in simplifying circuit design, but there is no consensus on a singular purpose or application, as various viewpoints and contexts are presented.
The discussion includes varying levels of technical detail and assumes familiarity with electronic components, which may limit understanding for those new to the topic.
This discussion may be useful for individuals interested in electronics, particularly those looking to understand the role of op-amps in circuit design and signal processing.
barneygumble742
hi,
i'm a little...a lot confused about op amps. in english, can someone tell me their purpose?
thanks
An opamp is a high gain differential amplifier, generally used between DC and a few 100kHz. It is usually a 3-terminal device, with +/- inputs and an output (plus power pins obviously). The key parameters of an opamp are the input characteristics (input bias and offset currents and voltages), the gain-phase characteristic plot versus frequency, and the output drive capability.
I googled opamp tutorial and got lots of hits. Here's the list:
http://www.google.com/search?hl=en&q=opamp+tutorial
It's correct that Op-amps are very useful.
They can replace many kinds of simple device used in our daily instruments, such as:
1. Comparators used as Sensors, Such as: light, water/wet level, temperature, motion, and so on, as long as we have the transducers.
2. Negatif feedback which they have, is very stable.
3. Their gain is very linear and steady, just like an ideal amplifier.
4. High input as well as very low output impedance, Etc.
In my opinion, for analog electronics, you'd better be very familiar with this tiny component.
Thx
hmm, the real reason you buy Op-Amps is that designing amplifiers from discrete components is difficult, and can be darn near impossible to match components. with an Op-Amp and a hand full of resistors, pretty much anyone can put together a high-quality circuit for isolating and manipulating an analog signal without getting an engineering degree and specializing in analog electronics.
to get a better idea of what they're "good for", it might be helpful to check out one of the Op-Amp "cookbook" type texts.
  • · Replies 78 ·
17K
