Temperature and Latitude: What Causes the Uneven Warming Across the Globe?
  • Thread starter Thread starter Mk
    Graph Latitude
The discussion addresses the uneven warming across the globe, particularly focusing on the higher temperature increases observed at higher latitudes. It highlights that the temperature variations are influenced by energy transfer mechanisms, where low-latitude energy is transported northward through water vapor and ocean currents. The efficiency of this heat transfer mechanism increases with climate warming due to higher atmospheric water vapor levels. Additionally, the northern hemisphere experiences greater temperature changes due to its lower heat capacity compared to the oceans in the southern hemisphere.
  • Understanding of climate dynamics and energy balance
  • Familiarity with atmospheric science concepts, particularly latent heat transfer
  • Knowledge of oceanic currents and their role in climate
  • Basic grasp of temperature measurement methods and their variability
  • Research the role of ocean currents in climate regulation
  • Study the effects of latent heat on atmospheric temperature changes
  • Explore the implications of climate change on polar regions
  • Investigate the differences in heat capacity between land and ocean
Climate scientists, environmental researchers, and anyone interested in understanding the mechanisms behind global warming and its differential impacts across latitudes.
Mk
http://data.giss.nasa.gov/gistemp/2005/2005cal_fig3.gif
Why does the latitude-temperture graph look the way it does?
"Why" do you ask? About the annual changes in its appearance? About the variations in general?
You're looking at fifty years of observations/measurements taken daily for every 10-20 thousand km2, some at established sites, some at transient sites, of a dynamic system. The temperature is not constant. The measurement method has not been conserved. The site locations have not been conserved.
If I understand correctly, your question is why do the higher latitudes have a higher temperature increase? And why is the northern hemisphere warming larger? If so, then here's the answer.
Irrespective of the source of warming (whether anthropogenic or not...), the climate variations at higher latitudes are always expected to be larger. This is because the temperature at low latitudes is mainly the result of the energy balance between energy emitted and absorbed at low latitudes, whereas at high latitudes, the story is different.
The temperature of high latitudes is governed not by the radiative energy reaching those latitudes but instead energy reaching low latitudes and then advected northwards through water vapor (and also oceanic currents). Basically, water evaporates (takes latent heat) at low latitudes, moves northward, condenses and releases the latent heat. Thus, the temperature at high latitudes depends on the efficiency of this conveyer belt.
When the climate warms, there is much more water vapor in the atmosphere. This implies that high latitudes can very warmed very efficiently, and the temperature difference between tropical and polar regions becomes relatively small. If the atmosphere cools, it also dries out, and the efficiency of this heat transfer is substantially diminished. The bottom line, the high latitudes are much more affected from any climate change.
The reason that the northern hemisphere changes more is because it has less heat capacity (the oceans) and can thus thermally adjust more easily.
– NJS
(http://www.sciencebits.com/" )
  • · Replies 36 ·
  • · Replies 54 ·
13K
  • · Replies 18 ·
12K
