Finding Tension in a Piano Wire Wrapped Around a Tuning Peg
The discussion focuses on calculating the tension in a piano wire with a Young's modulus of 2.0 x 1010 N/m2, a radius of 0.80 mm, and a length of 0.76 m, when wrapped around a tuning peg with a radius of 1.8 mm. After turning the peg through 2 revolutions, participants are tasked with determining the resulting tension in the wire. The problem emphasizes the need for detailed calculations to arrive at the correct tension value.
  • Understanding of Young's modulus and its application in material science.
  • Knowledge of basic physics concepts related to tension and torque.
  • Familiarity with geometric calculations involving circles and revolutions.
  • Ability to perform calculations involving stress and strain in materials.
  • Calculate the tension in a wire using the formula T = (Y * A * ΔL) / L, where A is the cross-sectional area and ΔL is the change in length.
  • Explore the relationship between torque and tension in a wrapped wire around a cylindrical object.
  • Investigate the effects of different materials on tension calculations using Young's modulus.
  • Learn about the mechanical properties of piano wire and its applications in musical instruments.
Physics students, mechanical engineers, and anyone interested in the mechanics of materials and their applications in musical instrument design.
jmccray
A piano wire (Y=2.0*10^10 N/m^2) has a radius of 0.80 mm and a length of 0.76 m. One end of the wire is wrapped around a tuning peg whose radius is 1.8 mm. The other end is fixed in place. Initially, there is no tension in the wire. Find the tension when the peg is turned through 2 revolutions.
What are your thoughts/ideas on this problem? You need to show your work to get help.
