Derivative of inverse trig function
The discussion revolves around finding the derivative of the inverse tangent function, specifically in the context of the expression involving a square root and a variable substitution.
  • Mixed
  • Participants explore the differentiation of the function y = tan^-1(x - (1 + x^2)^(1/2)), with attempts to apply the chain rule and clarify the substitution used for u.
Some participants have provided feedback on errors in the original post, suggesting corrections and clarifications. There is an ongoing exchange about the correct application of differentiation rules and the proper setup of the function.
There are indications of missing elements in the expressions, such as square root signs, which are being pointed out by participants. The original poster has made edits to their work in response to feedback.
suspenc3
Hi, can anyone check my work?
[tex]y=tan^-^1(x-(1+x^2)^\frac{1}{2})[/tex]
[tex]y^1=\frac{1}{1+u^2}\frac{dy}{du}[/tex]
let u = (x-(1+x^2))
[tex]y^1=\frac{1}{1+[x-(1+x^2)]} [1-x(1+x^2)][/tex]
thanks
Your post is littered with errors. :mad:
Edit: I've edited in for your forgotten square root sign. :mad::mad:
Here's how you may do it:
Set [itex]Y(u)=\tan^{-1}(u),U(x)=(x-\sqrt{1+x^{2}}), y(x)=Y(U(x))[/tex]<br /> Thus, we have:<br /> [tex]\frac{dy}{dx}=\frac{dY}{du}\mid_{u=U(x)}\frac{dU}{dx}[/tex]<br /> Or:<br /> [tex]\frac{dY}{du}\mid_{u=U(x)}=\frac{1}{1+U(x)^{2}},\frac{dU}{dx}=1-\frac{x}{\sqrt{1+x^{2}}}[/tex]<br /> Or, finally:<br /> [tex]\frac{dy}{dx}=(1-\frac{x}{\sqrt{1+x^{2}}})\frac{1}{1+(x-\sqrt{1+x^{2}})^{2}}[/tex][/itex]
oops..i made an error in my first equation..i edited it..can you check it now?
let u = (x-(1+x^2))
thanks
If you edited this after arildno looked at it, you are still missing a square root:
[tex]y=tan^-^1(x-(1+x^2)^\frac{1}{2})= tan^{-1}(u)[/tex]
for u= (x- (1+ x2)1/2).
  • · Replies 40 ·
